Question about Tissot T-Touch Expert T013.420.17.207.00 Wrist Watch for Men
Sensor tissot t-touch expert defect
I CHANGED THE BATERY AND AFTER THE PRESURE SENSOR DON T WORK. I WANT TO FIXED.I WANT TO BUY THE SENSOR
3 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: Hello, I just open my Tissot
I found another fellow on the web that changed his battery out, then it wouldn't come on, and he took it to a watch repair service, and they informed him it would be more to fix than buy a new one.
I suspect that the push button switch was orginally dirty, or partially oxidized, but it's also possible that the battery contacts, themselves, are oxidized. I would normally advice taking it in to an expert, since this is an upper end watch, and see what they think. If they feel the cost would be too much, I would try to take apart, and clean the battery contacts inside the watch with a qtip and alcohol, and then spray a bit of electrical contact cleaner on the push button switch (they're hard to get out to clean, and I just spray them).
I would at least have a jeweler check it out and give you an estimate or advice, then go from there.
Good luck, and hope this helps.
Posted on Nov 11, 2010
escapement
  • 2334 Answers
SOURCE: how do i set the time tissot t touch expert
Hi. As it would take a lot of time to write and draw all necessary figures right here, I would like to give you direct page address for all TISSOT TOUCH EXPERT settings. If the print is too small - use ZOOM tool to magnify it. Hope it will help. Follow this link: http://support.tissot.ch/usersmanual/141-en.pdf
Posted on Jan 13, 2011
Battery replacement is it a dealer only job?
This is a Myth my friend.Anyone can change a battery on Tissot T Touch.The First models have 2 steps the Battery Replacement and Synchronization.After the Tissot Expert add the Reset as third step.
In my blog i have instructions with video how can you do that.
www.watch4maker.com
Nov 24, 2013 | Tissot T33.1.588.51 T-Touch Dial
T-touch dont display altimeter, meteo and thermo. How can i reset it ?
I have the same problem with my t touch one, the first model with round push button, after take it to a battery replacement and service, and ask a tissot representative store, I receive two answers and both says that I have to change the movement... means ... the machine, and if is under warranty will be free, is maybe 6 or more years old so no more warranty, sad but true, I let it be. I will not spend at least 400 USD. to do it, so, try to enjoy the rest of functions left and a nice looking watch.
Oct 28, 2013 | Tissot T-Touch T33759851
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
How do i set the time tissot t touch expert
Jan 13, 2011 | Tissot T-Touch T33159851 Wrist Watch
On my Tissot t-touch expert, i need to know how to change
1. touch middle of screen till you see 24h Cm or 12h Cm
2. press middle button
3. top button changes Cm to Fft (celcius meters to farenheit feet)
4. bottom button changes from 12h clock to 24h clock
Apr 05, 2009 | Tissot T-Touch T33759851
Centre Sensor no longer functioning
You are need to send it into tissot for a service. You cannot fix this problem on your own. There is a two year warranty for tissot. Hopefully you will be eligible.
Apr 04, 2007 | Tissot T33.1.588.71 Wrist Watch
Tissot T-Touch Expert T013.420.17.207.00 Wrist Watch for Men Logo
69 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
