Question about Fisher Price Open Top Take Along Swing
Chicco polly swing
Swing not working
5 Suggested Answers
SOURCE: My Starlight papasan craddle swing
Make sure the legs are pulled out all of the way by pulling the legs outward. Make sure the buttons snap into the notches in the motorized frame. Also check to be sure the legs are locked into position by pushing the legs inward. The legs should not move. Also if you can adjust the swing from side to side make sure it is locked in place. That should fix it.
Posted on Jul 22, 2011
  • 4044 Answers
SOURCE: fisher price aquarium cradle swing won't swing
It's been a while since I have dealt with these. There is usually an off switch located along the swing bar check to make sure it is in the on position and that the switch itself hasn't been disconnected. Double check to be sure the swing is level and the safety isn't stopping it from working.
Posted on Nov 18, 2011
heavenly_bre
  • 18 Answers
SOURCE: swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Posted on Sep 13, 2012
heavenly_bre
  • 18 Answers
SOURCE: fisher price my little lamb baby swing will not swing
If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
Posted on Sep 15, 2012
Testimonial: "thank you very much!"
Chicco polly seventy - replacement foot rest
There is no parts replace for that.But you can try your nearest artisan or handyman or inventor to see if he can make one.
Oct 23, 2011 | Baby Gear
I need a replacement cover and harness for a polly magic high chair - any idea hwere I can get this?
Have you tried contacting the manufacturer? I believe that high chair is made by Chicco. There US phone number is
1-877-4CHICCO (244226).
Customer Service Option: 6
HOURS OF OPERATION:
Mon - Fri, 8 am - 5 pm est
info@chiccousa.com
You could also try stop by toysrus and see if they sell replacements.
Hope this helps
Mar 13, 2011 | Chicco Polly Highchair
Hi can you tell me if i can buy a replacement harness for my chicco highchair?
You may order replacement parts by contacting Chicco Customer Service at 1-877-424-4226. I wasn't able to find out if this particular part is available for replacement, but I sure if you call they will tell you
Feb 01, 2011 | Chicco Polly Highchair Adventure Stroller
Where can i buy chicco polly high chair replacement straps?
I did alot of searching on the internet for straps and found highchairbelts.com that didn't charge an arm and a leg for shipping or handling . One strap was $9 shipped so I bought three for $17 shipped FREE!! I sewed the ends of one strap together to use with Marissa's shopping cart cover at the grocery store. The ones on the carts are usually broken or missing and end or just plain filthy!
Mar 01, 2010 | Chicco Polly Highchair
Help i need a new cover for my chicco mamma chair its 8years old and upto baby boy no.3 its goven to cover heaven :(
yes, you can I know you can buy spare like that from www.buggypitstop.co.uk there are angels to deal with heaven knows. :)
Feb 12, 2010 | Chicco Polly Highchair
I HAVE A CHICCO POLLY HIGHCHAIR THE SEAT PADS NEED REPLACING CAN YOU ADVISE ME WHERE I CAN PURCHASE THE SPARE PARTS PLS
yeah i also just bought both the padded seats for the polly highchair for 25 pounds including delivery and a new harness for 10.50 it came the next day so easy just phone chicco on 01623750870 hope this helps
Oct 09, 2009 | Chicco Polly Highchair Adventure Stroller
Chicco Polly high chair - the padded cushion seat has torn in several places and the dirt and crumbs gather and rot!, can I buy a spare?
does the bottom of the seat have screws that you might be able to replace the foam padding from a craft store and buy vinyl there as well; like recovering a kitchen chair?
Aug 10, 2009 | Chicco Polly Highchair Adventure Stroller
Cant find replacement tray for high chair
Is this for the chicco polly highchair? I also rested my tray on the hob and it melted! I contacted Kiddicare.com who sell replacement parts for the chicco highchairs - it was £20 incl. P&P
hth
Jan 22, 2009 | Chicco Polly Notting Hill Stroller
Fisher Price Open Top Take Along Swing Logo
193 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
