Question about Camping, Backpacking & Hiking
Need to know battery type for older model JML 2288 flashlight/radio
How to put batteries in flashlight
Ah, a 'flashlight'. I changed the category from Cameras for you. You said 40429t0ss 340 in last post :>)
What is the type of battery? Make and model of flashlight?
Reply by way of comment below my post
Dec 05, 2016 | Camping, Backpacking & Hiking
Streamlight Model 4, AA, Propolymer Torch: It's an older model never been used, have put in new batteries & it will not work at all. Any solutions?
If batteries were left in the flashlight, it could be corroded on the most inner contact, shine a light, if it's green, try cleaning with alcohol and some scotchbrite, roll it up to fit inside the barrel.
Jun 16, 2015 | Camping, Backpacking & Hiking
Model: KP028 It doesn't work no matter how long I tried to charge it. I haven't used it for a few months though. Is there anyway that I can make it work again?
the batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
Dec 30, 2010 | Duracell Crank Light 3 In 1, 3 Led...
Am using ubuntu lts10.04...i want 2 use huawei ets 2288 modem
from the "UBUNTU SOFTWARE CENTER" in your applications menu, type in the search box "MODE SWITCHING DATA FOR USB". Then install it, after completing the installation insert your huawei ets 2288 modem and it will be recognized by your system. Then configure the connection with your internet provider.
Aug 27, 2010 | Canonical Ltd. Ubuntu
Battery died on my 2000 honda accord- need code
Sorry, there are virtually an infinite number of possible codes.
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code (some people say that they have found the code on a sticker inside the glove compartment, but I wouldn’t count on that). Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
I'm sorry I can't be more helpful than to let you know how to begin the process.
Nov 18, 2009 | 2000 Honda Accord
Need battery charger
Bought a universal charger from Radio Shack with plug that match spotlite.
Jun 23, 2009 | Duracell Crank Light 3 In 1, 3 Led...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Need a user manual for a jml halogen cooker
I have just ordered a halogen oven but would like instructions and recipes
Apr 04, 2009 | Microwave Ovens
Smartset CKS 2288
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Mar 09, 2008 | Emerson Smartset Clock Radio
Camping, Backpacking & Hiking Logo
95 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
