I have a Akai AC-GS09HRC air conditioner which is flashing run and sleep but won't start has anyone experienced this not in manual supplied
Unable to find any info on web
Krazytech
  • 725 Answers
SOURCE: E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Posted on Jul 26, 2008
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 92 Answers
SOURCE: NEED INSTRUCTION MANUAL FOR MAYTAG AIR CONDITIONER
maytags website probobly has that manual.
Posted on Jul 10, 2009
  • 400 Answers
SOURCE: Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Posted on Nov 19, 2009
qasolution
  • 107 Answers
SOURCE: York Air Conditioner unit doesn't turn on
jumper red to yellow on thermostat if it kicks on problem is in the thermostat.
Posted on Apr 22, 2012
EQ keeps flashing on Akai air conditioner how to fix
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem.
AC Repair Company
Feb 24, 2016 | Heating & Cooling
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Why won't my air conditioner change fan speeds
Having same problem...ac unit seems not to be changing fan speed and cooling level has been reduced ????
I have no solution. but we have just run into the 7 day of 95+ degrees with high humidity. do not believe the units have frozen up, just seems that the fan is in low speed mode and trying to raise it to F2 or F3 doesn't seem to help.??? Most of the time we have to increase temperature because its too cold ?? now it doesnt seem to be cooling the same ??? I await anyones solution.
Aug 06, 2012 | Kenmore 75121 Thru-Wall/Window Air...
Hyundai 24000'btu ac outdoor unit con moter wirig what runing'starting'comon
Three pins Common is neutral. Start is start from relay, Run is run from relay Usually Common at top, Start bottom left, Run bottom right but check a manual if you can find one.
May 18, 2012 | Heating & Cooling
I have a coleman rooftop unit and the compressor doesn't start. I am wondering if it could be the freeze snesor thermocouple? I am not sure how to check it? How do I check the compressor start...
Here's a link to service manuals but be advised, there are many potentially fatal items such as capacitors, even when power is off, that can give excessive shocks to anyone not experienced in this field. I strongly advise you to seek experienced help rather than attempting to test any of these circuit if you are not experienced.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 12, 2011 | Dometic Rooftop RV Air Conditioner
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
