Question about Apple Cinema Display 23" HD Monitor
Monitor will not power on
I recently acquired a used (but in very good condition, came from a TV production) Apple CinemaDisplay HD. At first, it worked fine. Suddenly, it would not turn on (ie the screen stayed blank) despite a blinking white indicator light. Now, it will not power on at all. I tried replacing the 90W power supply with a new brick, but it still doesn't work. Is there a way to fix this? My first guess is there is a problem with the embedded/power cables.
    New Friend:
The best sway to deal with apple products is to bring it to apple themselves......9 out of 10 times they will fix it for nothing
Posted on Jan 22, 2013
SOURCE: blank screen (Apple Cinema HD 23"LCD)
Had a similar problem with similar symptoms. Try unplugging the firewire and usb. Might help for a while. It did for me. In the end I risked the price of a new power supply. That fixed it and my 23" has been working fine since. Have to order the power supply directly by contacting Apple's service people. I found no other way to get one.
Posted on Sep 14, 2008
  • 3 Answers
SOURCE: Apple 23" HD display screen is black, power is on...
you need to open it up and replace the backlight(s), you will be quoted nearly the price new to get this fixed. might aswell bin it or eBay it! you intrestedin selling it?
Posted on Jan 11, 2009
SOURCE: apple 23 monitor 3 blinks and then pause, top screen is dim.
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Posted on May 14, 2009
SOURCE: Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Posted on Jul 20, 2009
Moozler
  • 3 Answers
SOURCE: Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Posted on Oct 27, 2009
I recently moved and no longer have a television. I would like to stream tv on my monitor for my apple desktop. What is the best way to go about doing this and the possibility of using a remote?
The only way you can do this is to use web based television like Crackle or Web360. The problem is you are tied to what they wish to show you. You can use YouTube for some series, and also your local television stations have some type of online content.
As far as remote control is concerned, you can use a wireless key board and mouse on your lap.
Here is some reading for you.
Web television - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Web_television
  1. Cached
  2. Similar
Web television (abbreviated web TV) is the genre of original television content produced for ... In 1999, Santa Monica based Television Internet premiered the eight-minute weekly series Muscle Beach. It was a sitcom, news and fitness program ...History - ‎Production and distribution - ‎See also - ‎Notes
How to Quit Cable for Online Streaming Video, Free Internet TV ...
www.digitaltrends.com/.../how-to-quit-cable-for-online-streaming-video/
  1. Cached
  2. Similar
Apr 25, 2016 - Cord cutting 101: How to quit cable for online streaming video. ... The thing about Internet-delivered TV is that you need a broadband connection that's copacetic with the streaming lifestyle. ... Cable TV doesn't interrupt your show to buffer, so when new cord-cutters are confronted ...Get an HD antenna - ‎Web TV - ‎Step 3 - ‎It's over! Comcast abandons ...
Watch Internet TV, Live Online Television, Web TV Channels
www.tvweb360.tv/
  1. Cached
  2. Similar
Watch Free Internet TV Stations from around the world on your computer. Over 1000 Free online TV channels. Large collection of live Web TV stations.
Apple Plans Web TV Service in Fall - WSJ
www.wsj.com/.../apple-in-talks-to-launch-online-tv-service-1426555611
  1. Similar
Mar 17, 2015 - Apple is in talks with programmers to offer a slimmed-down bundle of TV networks this fall, anchored by broadcasters such as ABC, CBS and ...
The Best Internet TV Sites of 2016 ' Top Ten Reviews
internet-tv-sites-review.toptenreviews.com/
  1. Cached
  2. Similar
Our experts have reviewed the best internet TV sites for 2016. See up-to-date comparisons on ... Web Services · Entertainment; Internet TV Sites Review.
The Knowns and Unknowns of Web-Based TV ' TIME.com
techland.time.com/2013/.../the-knowns-and-unknowns-of-web-based-tv/
  1. Cached
  2. Similar
Aug 22, 2013 - Like glaciers in the arctic, TV networks are slowly and inevitably warming ... How different would web-based TV offerings be from what's already ...
Apple May Launch Web-Based Television Services This Year ' TIME
time.com/3747136/apple-web-tv-service-25-channels/
  1. Cached
  2. Similar
Mar 17, 2015 - Apple is moving closer to making a foray into web-based television, ... and would be available on the company's streaming device Apple TV, ...
Apple reportedly working on a web-based TV service - San Jose ...
www.mercurynews.com/.../apple-reportedly-working-web-based-tv-servi...
  1. Cached
  2. Similar
Mar 18, 2015 - CUPERTINO -- Apple is reportedly preparing to release a web-based television service. The Cupertino tech giant is trying to bring various ...
Welcome to Web TV, cord-cutters. Don't forget your credit card - CNET
www.cnet.com > Digital Media
  1. Cached
  2. Similar
Dec 14, 2015 - The introduction of the first, legitimate Web-based television services happened in 2015. These new options stream live television channels.
May 05, 2016 | Apple 24" iMac Desktop
Apple Cinema 30 display powers on but nothing on a screen. Hi, Monitor powers on but nothing on a screen. Can anybody tell me what is caused the problem? Could this issue is caused by the...
Try to shine aflashlight on the screen and seeif you see an image. I have a Apple cinema HD 30 (A1083). I have no power. I checked the
power supply and it is good. I bought a main board from ebay. I still had the
same problem so I returned it (minus a 15% restocking fee). I read somewhere
that you have to have the usb cables plugged into the computer for it to work.
Is this true? If so I may have returned the part I needed to make this monitor
work. (just my luck) I bought this monitor for $25 used off craigslist. I am
really excited to get this working. I have heard great things about how
fantastic the dispay is. I am ready to do some gaming on it. I am an electronic
technician but not so familar with this apple monitor. I figured I would turn
to this forum to learn from some apple experts out there. Any imput would be
wonderful in troubleshooting my problem.
thanks
Tommy
Oct 11, 2012 | Apple Cinema HD 30" LCD Monitor
How do I connect my iMac 27" i7
You can buy an optional cable that you can plug into the mini-DVI or mini-displayport port at the back of your iMac.see example picture on: http://www.ecoustics.com/electronics/products/new/570842.jpgFirst you need to be sure to know exact if you have a mini-DVI or mini-displayport. The connectors are different and depend on how old your iMac is. Than you can buy the connector that fits your Mac. The you only need to check the connections on your TV. HDMI or DVI will give the best image quality. VGA is older and will result in a lower image quality. Last, you need to buy a cable between the adapter and your TV.
Jun 12, 2012 | Apple iMac Z0GF0005F Desktop
Angel kailen
The adobe software's require compatibility to computer systems to take effect for example, prior computers produced with office productivity software's adobe made document formatting achievable. Recently computer systems are several on the retails market with varies customer requirement least involving document productivity. Adobe is a document media productive program that should derive compatibility to any computer designed with such mentioned resources. Adobe program however recently has modification versions attain productivity depending in the type of computer and resources productivity requested. Usually, the software version at acquisition should be checked for compatibility with the computer on which would be installed. Also, since the adobe program is available on several versions that perform differently recognizing the version being acquire contributes to the installations process. For example, computer that has prior adobe programs would require undated versions of the software to attain success productivity. Also, the most recent version would only function on recent computers. Whenever a program is unable to perform as prescribe has certain conditions. First either least compatible to computer or version least provides resources that is productively requested from computer. Also, advertisement programs provide sample trial versions to make customer observations and later acquisition of the complete retail values. Any malfunctions with computer trial software's are likely expectations either for delevelopement program still undergoing invention not yet completely functional. Pursuing such computer programs on the retail market is unfeasible since not developed for customer acquisition. The trial versions only require feedback to the entity programmers. Adobe request programs are acquirable at retails stores where the complete customer versions are made available. Also, the retails stores make available program resources on the internetworked computers as an innovative improvement over acquiring to installing disk versions. Another means of resolving adobe program resources is referencing the computer supports experts sites from where code programs that resolves condition that happen to be adobe related is achievable. Also, usually computer innovation site makes available program resources from program network sites like www.microsoft.com mentionable. Acquiring resolution methods is achievable from network expert's specialty bloggers, chat conferences, innovators that responded to valuable to the computer innovations.
Feb 11, 2011 | Adobe After Effects CS5 Upgrade Windows...
I have the bd230 5.1 system hooked up the speakers, attached the power cord and hdmi cable from receiver to the tv what else do I need to get sound from my tv I have a hd cable.box do I need to run a cable...
The home theater box performs the production of the sound generation. Also, the theater box, distributes the sound to any display devices like TVs, Music MIxers, DVDR, VCRs, ext. The theater box also has connection ports that are recognisable as receptacle area from speakers, woofers, and twitters that combined to form the home theater of devices acquired. First, start by connecting the component parts of the theater system to the box. For example, speakers to an area on the box, twitters, woofers. At which point, the box would require a power cable to an electrican circuit to display functionality mode. The next step is deciding on which display reciver would be providing sound to the theater setup of blasters. For example, choosing to acquire sound from a TV set is achieved by connection cables that derived sound out of the TV to the theater box. E.G. The TV audio output area provides the connectivity of any external audio blasters like with the theater setup. Using the appropiate audio input output connection cables to acquire sound transfer matters. The device may not have been provided with a TV audio input out cable of connections. Acquire from retail input output cables from TV to theater boxes. Remember that, the theater box may have come with a remote control that require separe operations than the TV. The theater system theraafter would require power on buttons if any separate remote controls were acquired as well. Also, the television set would require alteration settings with the remote control. Adjusting the TV sound settings to acquire or direct internal sound to an external setup infrusture is possible explanation also achievable with TV REMOte controller soon after every wireing cables have been established alos powered on to source of current. GOOdluck
Jan 11, 2011 | Panasonic Home Theater System System
My cinema hd 30' display will not turn on nor does it look like its getting power
Hello, I have a Apple cinema HD 30 (A1083). I have no power. I checked the
thanks
Tommy
Aug 01, 2010 | Apple Cinema HD 30" LCD Monitor
The screen went blank/black no image, and power light still on. Can this condition be repaired?
Yes. Any TV/video repair store should have a qualified technician. Or, contact Apple, and find the nearest "authorized' service-outlet to you.
May 14, 2010 | Apple Cinema Display 23" HD Monitor
Just bought a use apple 23" hd display. The color seems to be somewhat yellow and is not a vibrant as my other apple 23" why
Optical components vary, especially when they have been pre-owned and subject to unknown temperatures and environmental conditions.
You can tune the yellow cast out of your monitor and improve the color range by opening Apple Menu / System Preferences / Displays, selecting the Color tab on the screen in question (two will appear), and running the interactive calibration routine.
Feb 16, 2010 | Apple Cinema Display 23" HD Monitor
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
Need replacement external power supply for DISH TV LCD-40-500
Dish no longer supports these monitors but you can contact Prima World Wide (PWW) between the hours of 9:00 am and 9:00 pm EST at their toll free number 1-888-267-5004 for warranty or out of warranty service and they may be able to assist you in acquiring the external power supply needed.I wish I could be of more help but want to thank you for using Fix Ya.If I can assist you in anyway please let me know.
Oct 08, 2008 | Televison & Video
Apple Cinema Display 23" HD Monitor Logo
148 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
