Question about Cameras
I took five pictures with my camera and it quit working, why is this?
After taking four pictures the camera said "Memory card full." I deleted all pictures and took five pictures and the camera quit working.
    Sergeant:
  • 321 Answers
May be ur card got virus contain temp files or video in it.
use 8 or 16 GB card
Posted on Jan 11, 2013
jackboy
  • 2985 Answers
SOURCE: Memory Full
What size is the memory card. What picture size has the camera been set to? Check out your Manual for the images sizes viz a vis memory card capacity - and come back
Posted on Jul 13, 2007
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
Posted on Dec 12, 2008
Steve5
  • 423 Answers
SOURCE: memory card is full but there are no pictures on my camera.
Try using the "format" option in your camera's menu. That should wipe the card clean. There's probably a file or folder that the camera can't recognize as being one it created. You might also plug the card into a card reader and open it on a computer. The format option on the computer will also wipe the card clean to start fresh in the camera.
Posted on May 19, 2009
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
  • 11967 Answers
SOURCE: every time i take a picture on my camera it says
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Posted on Nov 22, 2009
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
Oct 24, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
Camera works oddly..
Format the card again.
The memory card should be formatted each time you finish transferring your pictures to your computer, in order to avoid exactly this type of situation.
Aug 03, 2012 | Nikon COOLPIX Cameras
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Even though I deleted all of the pictures, then took five or six, the message reads memory full. What's up?
Do you have an SD memory card inserted? Your camera only has a 32MB internal memory, which could easily fill up after taking 5 or 6 shots depending on what setting you have it on.
Mar 16, 2011 | HP CB350 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I just bought a new camera (a GE C1033) and I took 1 picture and it now says the memory is full. I do not have in a memory card, so how can I use the internal memory and make it so that my memory won't be...
Well, the internal memory isn't all that big but, you can reduce the image size and possible get four pictures out of the camera before the memory is full again. Best bet is to go get the memory card for that camera.
Dec 20, 2010 | Cameras
My Kodak Easyshare V1233 comes on stating "Interna; Memory Filled" I went in and cleaned it. But it seems like I only get 5 pictures that I can take after that. I take the five (the number in...
The V1233 has 32MB of internal memory. At 12MP, each image file is probably about 5 or 6MB in size. 32MB of memory will only hold 5 6MB files.
To take more pictures, insert a memory card into the card slot.
Dec 03, 2010 | Kodak EasyShare V1233 Digital Camera
I have an HP digital camera and I took 90 pictures of my trip to Mexico and now only four pictures show up. They were not deleated by mistake and were on the camera yesterday and today only four pictures...
Check to see if they're in the memory card by using a card reader or your cable (USB) hooked up to your computer. Look in "My Computer" to see what's on the card. If they're there, copy them to a folder on your computer. After you confirm they were copied, I would format the card in your camera using the camera's function for formatting.
May 09, 2009 | HP Photosmart M407 Digital Camera
Memory full indicator comes on after only taking five pictures
Ok you need to buy a DS memory card and insert it in camera ( this camera has very little bultt in memory( a $14.00 card will get you hundreds of pictures!) Please rate! this keeps this site free
thank you!
Dec 13, 2008 | Olympus Stylus 1010 Digital Camera
Screen shows full memory card
It's quite possible that it's actually taking photos and storing them to the camera's onboard memory and not the memory card, explaining why it gets full so quickly with two pictures and why you can only delete two pictures. Look for a setting to change the storage to the memory card.
Sep 07, 2007 | Olympus Camedia C-3020 Zoom Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
