Question about Vacuums
Dyson dc08tss-tbn vacuum cleaner cleaning filter
How do I clean out my dyson dc08tss-tbn vacuum cleaner?
  • Vacuums Master
  • 851 Answers
Hello, this is Ava with Think Crucial.
You may refer to your online User's Manual by clicking the link below on how you can clean the filters of your Dyson cleaner.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Posted on Jul 30, 2017
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site
Posted on May 18, 2008
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
How to clean filters for dyson vacuum cleaner
Hi Seema, it's Jack at Dyson.
DC27 Total Clean has two filters, engineered to last the lifetime of the machine in normal use. These should be washed at least once every 3 months using cold water without detergent, as shown in the video below. Allow at least 24 hours for both filters to dry completely before replacing them.
I hope this helps, but if you'd like any further guidance you're welcome to contact us directly by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Sep 08, 2014 | Dyson DC27 Total Clean Vacuum Cleaner
How do you unjam a dyson wand?
dyson vacuum cleaners have a fine screen filter that looks like a white plastic ring with a fine screen this needs to be cleaned or your vacuum cleaner will not suck.
see filter in video
Aug 08, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Hi Pamela, it's Jack at Dyson.
Underneath the clear bin is the exhaust outlet, where clean, filtered air is returned to the room after passing through the machine. This is totally normal and part of the machine's design.
I hope this clears things up, but if you do have any further questions please email with your contact details, and one of our experts will be in touch as soon as possible. You can also find help online by visiting
Best wishes,
Dyson Online Customer Support
Oct 24, 2013 | Dyson DC27 Total Clean Vacuum Cleaner
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have no suction.
just look up vacuum cleaners in the yellow pages of your phone book. almost all vacuum cleaner stores repair all models.
Dec 27, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
116 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
