Question about ASUS Computers & Internet
Laptop not charging - ASUS Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
It sounds like one of three things:
1. Battery itself no longer functions
2. Your Asus Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
If the problem is the motherboard, you can try to have it repaired but I don't trust many companies to do this kind of work. I outsource my motherboard jobs to a company called Laptop Rescue (http://www.laptoprescue.com/laptop-repair-2/). Coincidentally, they also sell laptop chargers in case that's the problem. Hopefully it's just a charger or battery issue and not a motherboard.
Posted on Jan 14, 2013
I have a new LB1 battery for my 2006 15 in.macbook pro it will not charge the test button on the battery shows it is full charge but will not turn on laptop or charge
The laptop is the problem and not the battery, check the battery contacts for corrosion or consult a specialist on how to fix your laptop.
Dec 10, 2014 | Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
My toshiba P205-S6307 battery is not charging when plugged in
To test your toshiba p205 charger:
To test the laptop:
Jan 07, 2013 | Microsoft Computers & Internet
Battery not charging
Is it a replacement battery ,you purchased, with the EXACT same specs? Some aftermarket inexpensive batteries do not work well with your laptop. How do you know it's not charging, by the Icon in the Tray Notification Area? Again sometimes aftermarket batteries don't have the ability to communicate with the software. The pin-outs are not the same.
Dec 09, 2012 | Computers & Internet
Its plug in but battery wont charge
To test the laptop:
Nov 28, 2012 | HP Compaq nc2400 Notebook
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
DELL laptop isnt charging but power cord will keep it on why?
Jenni:
Your battery has died. You'll have to buy another one.
Nov 24, 2012 | Dell Latitude D630 Notebook
Power is plugged in , battery is plugged in not charging with 0% available
To test the laptop:
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    Inspiron 6000-flashing battery light
    Since you said the battery is not charging, why don't you remove the battery and charge directly to see if your laptop adapter will charge your laptop. Because i for see your laptop adapter been bad that is why it is not charging your laptop.
    If it did not, it means your laptop adapter is bad and will need to be replace in order to charge your laptop.
    Just change the adapter as advice and your laptop will charge.
    Take care.
    Apr 19, 2010 | Dell Inspiron 6000 Notebook
    Computers & Internet Logo
    16 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
