I'm trying to program my universal remote to my Sanyo tv but I don't know what brand my remote is?
    Genius:
  • 1,669 Answers
Universal remotes are very cheap and very available. Just go out and buy one in your local drug store or electronics store. It comes with complete instructions for automatically detecting the codes necessary to run all of your usual devices.
Posted on Jan 11, 2013
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
PaulTulsa
  • 14 Answers
SOURCE: sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Posted on Feb 17, 2008
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: janesong universal remote codes
Hi have a janesong remonte control and no code for a sharp tv can anyone help thanks
Posted on Dec 26, 2009
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
Posted on Mar 04, 2010
My remote to my sanyo tv the volume want work why?
If you're using a universal remote control; try by set it with an other code said to your TV. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 22, 2014 | Sanyo 42 in. LCD TV
How to program a sanyo universal remote RMT- U110
Aug 23, 2014 | Televison & Video
Sanyo 50" Plasma DP50710 Remote will not work.
Try to synchronize the remote control with an other code to your TV brand.
Jan 23, 2013 | Sanyo Televison & Video
I NEED THE MANUAL CODE FOR A SANYO RMT-U130 UNIVERSAL REMOTE FOR MY SAMSUNG TV
If you know the setup codes to check with your TV brand,
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you do not know the setup codes, and wish to know more about setup codes and setup proceedings to many brand remote controls, check this site. General setup codes to check with Samsung brand TVs are : 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Jan 23, 2013 | Samsung Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
Nov 25, 2010 | Sansui Televison & Video
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
Oct 08, 2010 | Universal Remote Control Remote Control
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
Have SANYO COLOR TV - Model # DS27590 - trying to find the codes so I can program my GE universal to work with it.
I found the codes by going on line to various sites. I have two TV's a stereo, a DVD/VCR player that I wanted to program a universal remote for.
As far as how many devicces one universal will handle...I don't have the answer yet.
Thanks.
May 16, 2009 | Sanyo DS27590 TV
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
