Question about Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier
Support Question about RMS
I have a Sony Xplod 12" Sub. with a Rated Output of 380W and 1200W peak power. I have powering that, a Pioneer GM-5100T 2-Channel Power Amplifier with 760 Watts Max Power.
Now my question. I was given a perfectly fine Sony Xplod the same as above, but the amp isn't enough for both. I'm thinking sell the amp I have and buy one that will power both subs. FYI. I installed this all myself without knowing much about how amps and subs work in any detail...anyone with knowledge would probably laugh hysterically at the setup (or lack thereof). If you answer, please explain in detail if necessary. So, what is the max power I need in a amp to power the 2 subs? Thanks in advance!!
  • 79 Answers
Actually the amp should be able to power both of your subs. You have a 2 channel 760 watts amp
380 x 2 = 760 watts. If you want to go with a more powerful amp I would go with a 2 channel 2400 wats amp 1200 per channel = 2400 watts total. Which the peak power of your subs if you go over 2400 you have the risk of blowing your subs easily.
Posted on Jan 22, 2009
  • 21 Answers
You are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    Can i have box dimentions for my 12" xplod sub
    • Warranty Terms - Parts 1 year limited
    • Warranty Terms - Labor 1 year limited
    • Product Height 12"
    • Product Width 12"
    • Product Weight 7.8 lbs.
    • Product Depth 6-1/2"
    • Subwoofer Size 12"
    • Resistance (Ohms) 4 ohms
    • Bottom Mount Depth (inches) 10"
    • Woofer Composition Mica-reinforced woven glass fiber composite
    • Woofer Surround Rubber
    • Peak Power handling 1300W
    • RMS Power Range (Watts) 380
    • Cutout Diameter or Length (inches) 12"
    • Sensitivity 84dB
    • Frequency Response 30Hz - 1kHz
    • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
    Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
    Amplifier For Powering Sony Xplod xs-l121p5
    Pump the brakes!
    You need to know the RMS power rating of the sub you are powering.
    Dont exceed the RMS power rating of the sub by more than 25%.
    If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
    Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
    Bottom line, know your RMS numbers, not Peak.
    Byron
    www.distinctbeat.com
    Dec 06, 2009 | Sony Car Audio & Video
    Output problem
    dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
    Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
    Does a 1200W amp run 2x800W subs
    ya youll be fine 800watts is at peak power on the speakers
    May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
    Sub not very loud
    Hey buddy your question caught my eye because i have a buddy that was wondering the same thing not so long ago-and im no expert but i have had my run with rockford fosgate amps and a few sonys as well. So first of all if you know fosgates well you know that they ALL put out more power than what they are rated at -example your 400 watt fosgate amp is rated at 400 watts but if you got it new than it came with a birth sheet that shows you how much its really putting out-im just throwing a number out there but its probably closer to 480 actual watts. Now you get the sony amp and it says its a 1000 watts but its all bs -it actually is rated at 400 continous usable watts- so the reason that its not any louder than the fosgate is because you bought an amp with almost identical power output. The other part of the problem is that you are limited by your speaker-you could buy an amp that actually puts out 1,200 watts and plug it right in to your sub and its going to probably blow within 30 seconds or quite possibly catch fire. The numbers when dealing with car audio that you have to pay attention to are the R.M.S. power ratings - never look at the peak or max wattage because its all bs and yea its all bs- As i was saying you are going to be limited by your sub because as it stands right now you cant put much more power on that thing without blowing or roasting the coil. All subs have a limiting factor as to how much air they can move- this is called X-MAX and that tells you how far the speaker cone actually moves from start to peak excursion- once you have supplied the speaker with enough power to reach its x-max then thats it -no matter how much power you put on it it wont move any more air than that-and you will create heat and distortion if you try and thats just begging for a blown sub. If you want it louder than upgrade your sub to something that will move some serious air like a jl audio w7 or orion hcca subs -those subs can get it on like dammmmm or easier than that get another sub and then your moving twice as much air at a fourth of the price of buying a balls out jl w7-anyhow good luck with that
    Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
    Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
    asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
    series; posative of one speaker to negative of other speaker and that doubles your ohms
    parallel; posative to posative negative to negative and that cuts the ohms in half
    Is amp big enough for speakers
    To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
    It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
    Hope this helps!
    Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
    Pioneer Car Amplifier GM-5100T - 2CH 760 Watts Car Audio Amplifier Logo
    291 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Michael Kovalik III
    Michael Kovalik III
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
