Question about Dryers
Dryer won't start
Electric motor won't start when start button is pushed. The door is closed. This Speed Queen dryer is about 25 years old. Just put new belts on it. The model # & serial # can't be found anywhere.
  • 318 Answers
Belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Posted on Jan 22, 2009
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
Hi, I have a Speed Queen LTSA7AWN washer/dryer combo. It will not start hte cycle. After closing the door, the door light flashes.
This is a door lock error. The control is not seeing that the door was locked.
Try pushing the door closed where the door strike is. If this does not work you may nee to adjust the door strike.
Dec 28, 2010 | Speed Queen CTS99AWN Front Load Washer /...
Dryer stops running shortly into cycle. When button is pushed to restart, dryer groans. Holding button may get the unit going again - but it makes noise running and stops again soon. Bad motor? Bad...
Sounds like start winding switch. I would replace whole motor assembly. Try on ebay for a used one that looks newer. Used motors will save you some serious money.
Jun 21, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer-Speedqueen AES17AWF- was drying, I opened the door to check on something, closed the door and when I push the on button, it just humms and won't start up..It's been about 22 hours and there's no...
try turning the drum by hand both ways, it will turn hard, but it should turn, if it doesn't, then you have something caught in the blower wheel. If it does turn, close the door and try to start it again. Hope this helps!
Dec 06, 2009 | Speed Queen AES17AWF Electric Dryer
I have a Mcgraw-Edison speed queen Heavy Duty dryer. We used it last night and it worked fine except there was alot of condensation inside the dryer with a little water coming out the door. Now this...
You may have a venting problem. Check outside to make sure vent is blowing good. It is possible that the motor may have went bad with all of the problems associated with a clogged vent.
Dec 02, 2009 | Speed Queen AES28AWF Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Clunking whirlpool drier
rollers and or felts are cheap,
much cheaper than a new dryer,
and nobody now makes a dryer that will last 25 years.
I have maytags 1972, 1974, kenmore 1968, speed queen 1980,
in each apartment building used by 11 families, to keep them running costs peanuts
new dryers?, - 3 years is all you get before the $$$ starts
Oct 04, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
