Moretti Elite Portable Air Conditioner MYPH-18C water leak
Water leak from condenser outlet
  • 105 Answers
SOURCE: Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
dcp2
  • 63 Answers
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
  • 166 Answers
SOURCE: sharp air conditioner portable leak in bottom
You mean it's leaking around the AC's unit base? If so, here's a handy diagnostic article that specifically addresses this problem of yours, explaining the probable causes and solutions, a solution that may very well have to do with the condensation pump's malfunction or just debris blockage, among other things: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm This article should set you on your way! Good luck! Brad
Posted on Jun 13, 2009
  • 86 Answers
SOURCE: water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Posted on Jul 25, 2009
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
Unit is 12000 btu and leaking water
it has a hook up on the back,there is supposed to be a plug covering it and also supposed to be able to hook a hose onto it to drain the water,you have to drain them every day or 2
May 27, 2015 | Haier HPRD12XC5 Portable Room Air...
I have a moretti elite portable air con and it's not blowing cold air it's second hand and a red light is on saying water full
Air conditioners remove humidity or water first, look for the bucket inside and drain it. or it is plugged and not draining.
Nov 16, 2014 | Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Water leaking all over
Jul 23, 2009 | Heating & Cooling
My air conditioner is leaking water
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Jul 01, 2009 | Movincool Classic Plus 26 Air Conditioner
Bought Amana 7000 BTU portable air conditioner for my father and he is telling me that it's leaking all over. I thought it was a self absorbtion.
Self absorbtion means that the water is evaporated by the blower blowing air over the condensation. On very humid days there may be too much water to evaporate. There should be a drain outlet on the back and it may be blocked. Clean it if you can find it.
Jul 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Jan 23, 2008 | Heating & Cooling
Jun 13, 2007 | Maytag Portable Air Conditioner M6P09S2A
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
447 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
