Question about Toshiba Satellite A75-S206 Notebook
Laptop freezes when I start to type
My laptop freezes seconds after I start typing.
The display also staggers It looks like waves when you scroll up or down the page.
    Genius:
  • Toshiba Master
  • 1,102 Answers
Do a virus scan
and disk defrag
also check in devices see if any drivers have any errors
then i would do a windows update
when did this start to happen have you done any upgrades to the system
Posted on Jan 22, 2009
Screen not responding
Try to scan for antivirus it may your stuff infected.
Dec 24, 2012 | Computers & Internet
The alert is to loud, how can I turn down the volume for the alert?
Press the WEATHER/SNOOZE button to turn on the weather radio. Then press the "UP" or
"DOWN" volume button to select desired listening level. (Note: Turning the volume all the way
down [where no bars show] puts the radio into silent mode.)
Hope that helps resolve the issue.
Regards
Anand
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
How can I turn on and off the 3G on the samsung wave 8500
1- Press the Menu key
2- Touch Settings
3-Touch Connectivity
4-Scroll to and touch Network
5-Touch Network mode
6-Touch GSM 900/1800
7-Touch Set. After doing above steps on Samsung Wave S8500, the network type is 2G, if you want to turn on 3G, you can select UMTS 900/2100.
Jan 19, 2011 | Samsung Wave S8500 Smartphone
System freezes-Video display=multi-staggered image(not legible)
It's either a loose connection from the motherboard to the video-display, or a partially-broken video-display, or the video-adapter in your motherboard.
Connect an external monitor -- if it looks OK when the internal LCD is "wavy", then your computer is fine.
But, since your say "happens to both screens", the most-likely problem is the video-adapter, which usually means that you will have to get COMPAQ to replace the motherboard.
May 26, 2010 | Computers & Internet
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
HI i have dell inspiron 1420 and when it's booting machine is getting freeze if i press f2 to go to setup display is getting wiered colors and i can not go to setup menu or i tried to go to last known best...
click start....run....msconfig.
in the system configuration window select the startup tab on top right.
click disable all...click apply and ok
restart the system. this should fix the issue
Jan 29, 2010 | Dell Inspiron 1420 Laptop
Looking for chipset driver and display driver for a Toshiba Satellite U305-S5077 for XP Thank you
From the Start Menu, Type: Toshiba in the Search (box). Scroll to find; Toshiba Resources Page; click it. From the Toshiba Website you can find, and "Download Drivers." Just enter the Description and Model# of your Laptop. I hope this help!.
Jan 23, 2010 | Toshiba Satellite U305-S5097 Notebook
Graphing
Instruction book for this calculator is shocking for sure. It would take too long to explain fully, here is an example of plotting a simple Y= graph.
In main menu, when you first turn it on, press 1
This is normal calculator mode.
Press [shift] [menu] to get the set up parameters.
Scroll curser down one to Func Type, and select Y= if this is not already set, by pressing F1
Continue scrolling down to set Coord, Grid, Axes and Label functions. Turn these on or off as desired. Turn them all off for this example. F1 and F2 select On or Off here.
Press [exit]
Press [shift] F3 to access the V-window parameters. Here you set the size of the axis in the graph
Enter 0 for Xmin, 360 for Xmax, 0.1 for scale
Enter -1 for Ymin, 1 for Ymax, and 0.1 for scale
Press [exit]
Press [shift] F4 to enter graph plot mode (Sketch mode)
Press F1 then [EXE] to clear any previous graphs
Press F5 then F1 to select Y= type graph
Display should show Graph Y=
press [sin] [ X,0,T] (this key just under red alpha key) then [EXE]
Calculator should draw a sine wave, showing 1 complete wave
Try setting the parameters in Set up, Axes On, Label On etc to see the effect.
Hope this helps a little. Page 123 in book deals with graphing.
Mar 28, 2009 | Casio FX-9750GPlus Calculator
How do i connect to wireless internet on my a210 laptop?
Hi Junellespear;
I assume that your laptop is wifi ready,
This is for XP;
did you see an icon on your lower right corner that looks like a pc that has signal wave? if you do, right click on it and select view existing wireless network, and from there, choose and click connect,
if you have that but you are not able to connect, go to run and type in "services.msc" without quotes and from there scroll down and look for wireless zero config, right click on it and select start.
in order to further assist you, tell me some steps that youve tried. :)
Jun 18, 2008 | Toshiba Computers & Internet
Toshiba Satellite A75-S206 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
