Question about HP P2360AA Keyboard/Mouse
New HP keyboard & Mouse not working
I have a new HP computer plugged in the mouse and keyboard via USBs but neither is responding. The computer pop ups recognised them and the mouse lit up. I can't do anything on my new machine! I have unplugged them, turned the computer off and on but to no avail. I have tried different USB ports I have tried different keyboards and mice but still nothing works.
  • gadjet420 May 19, 2009
    the tower will not read mouse or keybord? why  an can i fix it by hooking it up to mine from eathernet
I solved this problem by
1taking off the tower cover
Posted on Jan 26, 2009
1 removing the tower cover
2 taking out the small round lithium battery
3 taking out one of the memory cards
4 starting up, turning off
5 putting it all toghether again
6 presto, the mouse and keyboard works
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
HP Keyboard and Mouse Not Working
install the utility program of that new HP KB n Mouse
Jun 17, 2009 | HP P2360AA Keyboard/Mouse
Hp wireless mouse not working
u still need the remote that plugs into the wall
if you have it it needs to be nearby like close
Jun 01, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Mouse and keyboard aren't working
have you tried downloading a newer driver for your computer? you might have to find drivers for both the mouse and your key board. make sure your numlocks is on for the keyboard to work, and make sure that in your control panel under hardware and sound check their for your mouse connections.
Jan 24, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Mouse and keyboard freeze after 2 seconds on desktop
Could be the battery on the Motherboard that need to be replaced. Just had the same issue and with a new battery in place everything works just fine
Jan 07, 2008 | HP P2360AA Keyboard/Mouse
Microsoft Wireless Mouse and Windows Vista
I'm having pretty much the same problem with my Microsoft Wireless 4000 mouse and my hp-compaq 8510p laptop. If I shut my machine down, or restart, my mouse no longer works. I have to uninstall/reinstall the Intellipoint software. The synaptics touch pad continues to work, but the mouse fails.
Dec 19, 2007 | Microsoft Wireless Notebook Optical Mouse...
HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Oct 04, 2007 | HP Wireless Optical Mouse
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
HP P2360AA Keyboard/Mouse Logo
261 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
