Question about Maytag Dryers
Dryer won't spin
We bought a used Maytag Dryer. When we went to use it the drum would not turn. We opened it up and discovered a broken belt. We replaced the belt. The drum will now spin with no clothes in it. It appears to spin slowly though. When clothes are placed in it, the drum will not spin at all and it makes a terrible noise. Where do we go from here?
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Posted on Jan 11, 2013
5 Suggested Answers
  • 55 Answers
SOURCE: Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Posted on Feb 01, 2008
  • 5 Answers
SOURCE: Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Posted on Dec 20, 2008
  • 195 Answers
SOURCE: Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Posted on Dec 06, 2011
  • 7 Answers
SOURCE: Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Posted on Dec 07, 2012
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dec 06, 2011 | Frigidaire Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Drum won't spin on it's own but spins freely by hand.Was slow to start spinng before. Took front off but can not see belt at all, if it has one?
drive belt is normally accessed from the rear of the machine or if sealed rear from underneath(bottom) the belt is normally easier to get off the drive motor pulley first . Sounds like your belt is either already broken or has come away from drive unit or drum .
Jul 25, 2011 | Maytag MDE508DA Dryer
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Dryer quit spinning.
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Dec 11, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryers Logo
114 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
