Question about Sewing Machines
What is the shuttle hook timing for Singer 97-10 harness stitcher?
Where are the adjusting screws to time the shuttle?
leethedeuce
  • 4472 Answers
SOURCE: Singer 1120 timing
http://www.sewusa.com/Sewing_Machine_Repair.htm
this page should help you. If you need any further assistance let me know. If you have a moment to accept and rate it accordingly I would greatly appreciate it.
Thanks,
Lee
Posted on Sep 07, 2008
Mimito7
  • 128 Answers
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
  • 980 Answers
SOURCE: how to check and adjust hook timing singer model
I can attach full instructions if you email me drivewithken@blueyonder.co.uk but remind me of your model and problem
Posted on Jun 25, 2009
  • 980 Answers
SOURCE: my singer sewing machine no. 127 vibrating shuttle
There are no adjustments at all on that model, it has to be down to the needle for some reason
Posted on Nov 02, 2009
  • 980 Answers
SOURCE: Please tell me how to Time the shuttle of a Singer sowing machine
email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Jun 26, 2010
How to repair a shuttle hook?
Unless it is rusted, probably needs some good quality oil and perhaps heat and time(patience)...
Wheel on right side that controls the needle up and down is very tight...
Nov 25, 2017 | Singer Sewing Machines
Sorry no stitches are forming on my singer promise machine everything else is fine
This may be a silly thing to ask you, have you made sure the machine is threaded up correctly, if yes is you shuttle bobbin full and fitted correctly so the tail of the cotton enters the side tension spring if applicable, if the answer is yes to both of these questions, then, check that the needle is the correct way round if all is okay there, then the next question is have you jammed the machine with cotton whilst trying to sew or have you broken a needle, if the answer is yes the possibility is that the pick up hook on your shuttle case as been knocked out of timing and is unable to pick up the shuttle bobbin thread, and are you confident enough to set the timing of the hook your self, the hook should be just and only just approaching the needle in it's lowest position as it is about to rise up again, depending how tight the hook assembly is on it's shaft is without undoing the clamp screw that secure it in place. Remove the bobbin and sole plate and rotate the machine by hand in the correct rotation and watch what the hook does as it approaches the needle if it's found to be out of position then hold the hand wheel tight, then gently rotate the hook case to it's correct position as described a above, you will need to use a screw driver or something of that nature to achieve this, only lever a small amount at a time you will feel a slight resistance to rotate in either direction. Once satisfied you done it correctly recheck before you run machine.
Good luck to you.
Mar 08, 2015 | Singer Sewing Machines
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
How to adjust M5 Screw on Singer 7463
What makes you think your timing is off? What is it doing/not doing that makes you think it's off? Before you do anything ,make sure your needle is all the way up in the clamp. A needle inserted too low--even a little--can cause the same symptoms.
Aug 15, 2014 | Singer Confidence 7463 Computerized Sewing...
I cannot get the top needle thread to pick up the bobbin thread on a Singer 404. I have the manual online and can see that I have loaded everything properly, but the bobbin thread just sits there when I...
Hi Jennifer:
Do you understand how a stitch is formed on a sewing machine? The needle goes down to its full down position. At that point the shuttle hook should be pointing right at the needle scarf, ready to go past it as the needle starts to go up.
When the needle starts its upward travel it forms a loop... the shuttle hook enters the loop and the bobbin thread is "captured" in that loop.
If your machine's timing is advanced, the needle will hit the hook and break or make nasty thumping noises. If your timing is ********.... the hook misses the loop entirely and does nothing.
So... open up the entire bobbin/throat plate area.... take the foot off so you can see. Clean if necessary. Then turn the hand wheel by hand until you see that the needle is at the lowest point of travel. Where is the shuttle hook?
From there you'll have to use your logic to find the right screws and adjust the hook.
Here' is a Parts Chart for your machine.
http://www.parts.singerco.com/IPpartCharts/404-1_4_5.pdf
Sep 14, 2012 | Singer Sewing Machines
Brother 1120 sewing machine timing adjustment
Easy to do remove sole plate remove shuttle and case, don't forget to pull the spring loaded plate to one side by inserting a electrical screw driver in the slot and twisting it anticlockwise to release the case, remove drive dogs this will the expose the cotton pickup assembly turn the hand wheel anticlockwise until the hook gets close to the needle now watch the needle it should be in the lowest position and just as it starts it's way back up the hook should be just going behind the needle to pick up the tread if this is not the case and it's out of position then hold the hand wheel tight and insert a small screw driver into one of the gaps in the base were the shuttle case fits in away that you are able to move the hook assembly one way or the other with a gentle pressure and move the hook just to make it enter just behind the needle as it only just starts it's way up at this position it is now complete and you can reassemble and run slowly at first just to make sure things are okay.
Happy Sewing
Oct 15, 2011 | Singer 1120 Mechanical Sewing Machine
How do I fix timimg on a singer 2263
There should be one or two set screws behind the bobbin shuttle, they could also be in the bobbin shuttle. You will loosen them st the timing and then retighten them. The Timing on a sewing machine is really straight forward, but that doesn't mean its not a pain in the but. When the needle is at the bottom of its travelthe hook on the shuttle should be coming around to meet the needle. As the needle starts back up it will create a loop in the thread for that hook to catch. Therefore the needle needs to start up before that hook is directlly in line with the needle. But the hook has to be above the eye of the neelde. So rotate it back and forth with no thread and watch to see when the hook passes the needle. It will probably take several attempts but you can do it. Do it in small movements. and only tighten the set screws enough to hold the shuttle in place to check it. Do not forget to retighten them.
May 27, 2010 | Singer Sewing Machines
Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
May 20, 2010 | Sewing Machines
Singer sewing machine jammed after sewing over straight pin
The shuttle and needle timing needs to be re-set. Also the hook needs to be inspected for damage.
Oct 14, 2009 | Singer Sewing Machines
May 12, 2009 | Singer 3116 Simple
Sewing Machines Logo
81 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
