Question about Nokia 2760 Cellular Phone
Battery backup problem for nokia2760 - Nokia 2760 Cellular Phone
Nokia2760 no network
Go into your settings and put your phone into airplane mode for ten seconds, then turn airplane mode back off.
If this does not work do a hard reset on your device by pressing and holding the lock screen/power button.
Thanks,
Dish Guy
Apr 23, 2014 | Nokia N Cell Phones
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Unlock nokia2760
    You can unlock Nokia 2760 using unlock codes! Unlocking using codes is easy and safe than other methods! You can get the codes from your service provider or from reliable online sites like classicunlocking.com .For unlocking instructions you can visit mobileunlockguide.com ,here you can get simple and step by step instructions to unlock your phone!!!
    Jun 07, 2012 | Nokia 2760 Cellular Phone
    Forgotten my security code nokia2760
    ur defalt phones codes is 12345 or 00000 u can use it
    Default 4 Digit user code: 1234 or 0000
    Default 6 Digit Security code: 123456 or 000000
    Default 6 Digit Security code: 000999 or 1122
    Type *#06# at the mobile screen to know IMEI no of your mobile.
    send the IMEI no to me and i will reply you with unlocking code.
    IF Problem not Solved So
    Please New Software install in the Phone Problem will Solved
    OR:
    If For puk & pin cod problem So Please
    Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
    Enter The Puk code and Yes
    Enter The pin code and Yes
    So Puk code Open and Problem will Quickly Solved
    Aug 22, 2011 | Nokia 2760 Cellular Phone
    How can i watch online videos in nokia2760
    Hello, you cannot watch online videos on this phone.
    Hope it helps.
    Jun 08, 2011 | Cell Phones
    Want to set volume on my hearing cannot hear person when somebody phones me how do I set it regards Jan nokia2760
    To increase the volume of earpiece, when on call press right navigation/scroll key to increase the volume and press left navigation/scroll key to reduce the volume.
    Thanx
    Jul 23, 2010 | Nokia 2760 Cellular Phone
    My computer wont let me install my usb cable for my phone nokia2760
    GET A ORIGINAL CABLE.IF U HAVE THEN GO TO CONTROL PANEL OF YOUR COMPUTER AND CHANGE SETTINGS
    Oct 31, 2009 | Nokia 2760 Cellular Phone
    The battery backup is very low
    Looks like either the devices connected to the backup battery are consuming too much power than that backup can handle or the backup battery is getting worn-off. You may need to change the batteries or take-off some load (remove some devices that consume power) from the backup battery.
    Feb 03, 2009 | LG KU990 Viewty
    Nokia 2760 Cellular Phone Logo
    22 people viewed this question
    Top Nokia Cell Phones Experts
    270rexton
    270rexton
