CANON IR ADVANCE C7055 HAVE AN ERROR E025-0210
IT'S GOT AN ERROR "E025-0210" ON DISPLAY PANEL. PLEASE CAN SOMEONE ASSIST.
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
hquiteculo
  • 19 Answers
SOURCE: Error code E000025-00001
there is a toner feed motor over currente detection error, there is a toner botle motor connection detection error.
1- check the connector for any fault in connection.
2- replace the motor
Posted on Apr 09, 2009
  • 66 Answers
SOURCE: my canon ir 1018 displays this error code e808 and does not print
has the machine been serviced recently? if not, unplug machine for 10 mins, then plug back in. if the code comes back the fuser assembly will need to be replaced.
Posted on Apr 13, 2009
SOURCE: Canon ir 3100 cn error code e000020-0081
it can not print out
Posted on Feb 10, 2010
Hp support assistant 'how to fix'
Remove it. Click Start/Control Panel and look for Programs and Features, or Programs (depends on your operating system). Uninstall the HP Support Assistant. It's not needed, just a bloated program on your system.
Apr 13, 2012 | Computers & Internet
Data Transfer error
You need new lower power board some people say lower circuit board . This will cost around 280 but anyone looking to buy I have got one brand new.contact me on 07943858686
Mar 14, 2012 | Tunturi T85 Treadmill
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
All front panel are blinking- lexmark E232 printer
When all the lights on the printer's operator panel blink at the same time, the printer is displaying a primary service error. This indicates that something has failed in the printer. In order to determine what has failed in the printer, you will need to obtain the secondary error code. Please the continue button twice to see the secondary code. Once you have the secondary error code, please call Lexmark Technical support for further assistance.
Aug 18, 2011 | Lexmark E232 Laser Printer
Hotpoint Ultima WT965 is giving me an F12 error on the display. When I switchoff and on at the plug the display doesn't come on properly, with random lighting of the digital display element. Any...
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PC hence the intermittancy- just needing re-seating- by an engineer ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 14, 2011 | Hotpoint Washing Machines
The machine start to work ,but then i can see 5d and i don't know what it means
Hi
Error code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Aug 10, 2011 | Kenmore Washing Machines
Lg washer LE error: motor will not turn with a load and displays error quickly when I run it empty.
LG's 'le' stands for 'Lock Error'. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 22, 2011 | Washing Machines
Samsung wf306baw/xac: after filing with first water, stops, problem tone and te display
'te' stands for Thermistor Error. (quote) 'If the thermistor circuit is abnormal, this error will occur. If thermistor is lower than 0.2V or higher than 4.5V this error will occur. This error will be released by turning off power switch.' (unquote)
Sorry but I would suggest it requires a service engineer's attention ;-0(
John C
Jun 04, 2011 | Washing Machines
Displays Error Code 1203 - What is that? User Manual is lost.
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 05, 2009 | Lexmark X7170 All-In-One InkJet Printer
483 people viewed this question
k24674
jasbo
jasbo
