My Samsung 7 kg Washing machine serial no j1043 is leaking water water and the middle section where u put soap powder is always ful of water
  • 16 Answers
SOURCE: my washing machine wont take the soap powder and softener
It could be a water inlet valve that is at fault. Are the hot and cold supplies turned on? Try opening the powder draw very slightly when the machine is filling with water, if no water in powder draw, chances are that the inlet valve is at fault, situated on the inside of machine where the filler pipes connect. Unplug machine from power supply before checking the inlet valves with a resistance meter, making sure to disconnect wires from one terminal to avoid false readings. Tom.
Posted on Mar 09, 2007
  • 188 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 21, 2009
  • 22 Answers
SOURCE: washing machine not draining or spinning. samsung
Samsung washer drain pumps usually have a trap that may be holding a large amount of debris (buttons, pins, coins, etc) and lint packs around all of it and the water can't drain, which means the unit won't spin. A more complete model number would be required to find out if the trap is accessible by removing the front panel or not.
Posted on Apr 25, 2009
  • 447 Answers
SOURCE: Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Posted on Dec 28, 2009
SOURCE: i have a samsung J1043 7kg washing machine, apon
3E means the motor is running below or above the programming RPM's, this is a real problem. hold down the two left buttons while pressing the power button. this will present you with the testing system. Press the temp button and T1 will appear. press the start button on the machine will move through the phases in 3 second bursts. if your drum doesn;t move your motos shot. Good luck
Posted on Jan 31, 2010
Where do I put the liquid soap for the wash
Lichid soap for automatic washing machines is not indicated, since foam is produced and can be a nuisance when coming out from every seal and can perturb the function of some sensor.However, if needed, can be poured on the powder tray (100 ml) for about 5 kg of laundry or directly inside machine, on top of laundries is better. Don't forget to close the door afterwards.
Sep 10, 2017 | Washing Machines
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
Water is coimg out from the section were you put powder in
even the water pressure to the washing machine is too high, the machine is tilted forward or a blockage in the soap hose/ draw inner preventing water going down.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Feb 19, 2010 | Bosch Washing Machines
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
