Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Sears forced air kero heater wont start, spitting fuel out front
My 60,000 btu forced air HSI technology heater. When i plug it in, the unit tries to start for about 5-10 seconds then shuts off. I wait a couple minutes then try again, same thing and also see some fuel coming out the end (like it is pumping fuel but not firing). If i repeat about 10 times it eventually fires up but then shoots flames out the end as it burns the excess fuel that has accumulated and smokes a lot for a few minutes or so then burns cleaner. I am running diesel fuel and it is about 25 degrees where it is being started. I was going to clean or replace all air filters, blow out fuel filter, re assemble then check fuel pressure. Would this be the right course of action? Should I also replace fuel nozzle?
  • dksfresh Jan 27, 2009
    I got it resolved for now it seems. I adjusted the fuel pressure , then let the heater run until it burned all the diesel fuel in the tank. I then filled with fresh kerosene and now starts right up and seems to burn cleaner. Maybe the diesel was gelling up or had some condensation in it. Also I ordered a filter kit and when I receive it , will change these out. The ignitor seemed to be o k .
  • 92 Answers
Sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Posted on Jan 22, 2009
Ran out of fuel now wont start
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 11, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Ran out of fuel and it wont restart
did you put new fuel in and press the reset button located near the plug?
Feb 10, 2011 | Reddy Heater 60,000 BTU Kerosene...
Heater will not start
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Heater wont start.Fan goes, Starts to heat, then blows a couple clouds of smoke and dies. Ive cleaned filter, new fuel. Cant figure out what adjustment I should be doing. Glow Plug? What else?
take the shield off and see if it burns with more combustion air. If it does then the heater isnt getting enough air. look for a shutter or set screw near the burner that should be the primary air adjustment. sounds like you have been working on the fuel side already. You may check the orfice to see if it is partially blocked, use a safety pin and gently **** it out. also check the burner tube
Dec 07, 2009 | Reddy Heater 60,000 BTU Kerosene...
Where can I get a pressure gauge to adjust the kero heater pressure ..... the kero odor is bad
go to mcmaster-carr industrial supply. the air pressure should be around 3-5 psi on that heater.
Oct 12, 2009 | Reddy Heater-30,000 BTU Propane Forced-Air...
Remington 60 portable forced air heater 60,000 btu
I had the same problem. I took the nozzle head off and blew through it with air. I also blew through the air line, this is the one that goes to motor. It has worked fine ever since.
Dec 16, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
865 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
