Question about Lasko Ceramic Heater
Constant Rotation I bought a Lasko 360 stand up rotating heater from Lowes in October. I brought it home and it worked fine for a little while (meaning I could make it rotate 360, 180 and 90 degrees or stay still). Suddenly it stopped being able to be adjusted and only spins 360. When I set it on 90, 180 or 360 it appears on the display like it is doing the correct thing (even though it isn't) but when I set it to stationary it blinks.
  • 2 more comments
  • Anonymous Feb 01, 2009
    yeah same problem here
  • Anonymous Feb 28, 2009
    Same here... it worked correctly for about a month.
    Same here... it worked correctly fro about a month.
  • scampana Mar 13, 2009
    I have the same problem. It worked for a month, then reverted to 360-only operation. Lasko says they will replace it. I think I'll return it to Lowe's and get one with limited rotation.
  • 4 Answers
SOURCE: Lasko 5365 Ceramic Compact Heater Troubleshooting Forum.
Try taking a can of compressed air and spray in the vents in the front and the back of the heater. The heater has a sensor that gets dusty and causes it to shutoff to prevent overheating.
The heater should function properly once the dust is blown off the sensor.
Posted on Feb 19, 2008
SOURCE: Heater won't get hot
I went on several websites until I located the company. Recieved a call from them to day and they are sendin me a manual.
Posted on Dec 16, 2008
reddyanantha
  • 205 Answers
SOURCE: dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Posted on Jun 22, 2009
  • 832 Answers
SOURCE: Our Lasko 5620 has a digital control, but we can't
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Posted on Jan 10, 2010
markfreedman
  • 312 Answers
SOURCE: My Lasko 5805 heater worked
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Posted on Jan 02, 2011
Was putting on a wall mount and a screw broke off in the tv.
You can try a screw extractor. Take this video to regular old fashioned hardware store ( not Home Depot or lowes bc they won't have a clue) and show them this video. This bit has to work in counterclockwise rotation to work.
Mar 02, 2013 | Televison & Video
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
My lasko fan stopped blowing air
The rotation gears have gotten clogged up, take it apart and put some grease or oil in the rotation parts/gears and work it in until it spins freely. Will work like a charge afterward. I had to do it once myself already.
Sep 24, 2010 | Lasko 2530 Elite WindTower Fan
Dec 15, 2008 | Lasko 5520 Ceramic Compact Heater
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
Only a little heat is going to the cylinder
Zuraxus what you are seeing is normal for a time. Here is how this dryer works. With a wet towel in the dryer, the first 5 minutes is testing to see if the load is wet. If so then between 5 & 10 minutes the dryer will turn on the 800 watt heater section (only in clockwise rotation). If still wet enough from 10 minutes to 15 minutes it will turn on the 1900 watt heater (heating only in clockwise). If still wet enough 15 to dry will turn on the full 2700 watts in clockwise and 800 watts in counter clock wise. That is how the cycle works. However it is hard to tell with the rear cover removed as the blower pushes the air thru the heater. Careful that by running with the back panel off you don't trip the high temp manual reset protector. So yes this sounds normal. What is the issue that is causing you to think the dryer isn't working proper?
Apr 20, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
May 11, 2007 | Lasko 2530 Elite WindTower Fan
Lasko  Ceramic Heater Logo
156 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
