Question about Intel Motherboard
Power surge on Hub Port
I connect HP Printer, Modem in CUP but few days Monitor shows "Power Surge on Hub Port" what is the problem pls. solve
  • 1,602 Answers
GO TO CONTROL PANAL OPENTHE FOLLOWING FOLDERS
DEVICE MANAGE AND LOOK FOR ANY MARKS OTHER THAN GREEN ONE, THAN CLICK ON THEM AND ASK FOR HELP ONLINE.
GOTO CONTROL PANAL AND OPEN THE FOLLOWING FOLDER NETWORKING AND SHARING, CHECK FOR MARKS.
GO INTO PROBLEM AND REPORTS AND OPEN THE FOLDER AND CHECK FOR ANY TYPE OF MARKS
GO INTO SYNC CENTER CHECK FOR ANY MALFUCTION OR WRONG SOFTWARE AND FOLLOW THE INSTRUCTION TO FIX THE ERRORS
ROD GANDY
Posted on Feb 12, 2009
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
A USB device has exceeded the power limits of its hub port
Windows display this message when a USB device is short-circuited. Try another USB cord or connect the usb to the port at the back of your pc. If it does not help then the problem resides in the printer. I will not suggest to dismantle your printer as there are no user serviceable parts inside.
Aug 10, 2009 | Canon LaserBase MF5650 All-In-One Printer
Power Surge On Hub Port
try to test the camera on another pc..There is 2 probability here, either it is faulty or else there is something wrong with your usb connection...
Jun 16, 2009 | Logitech QuickCam Pro Webcam
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
HP Pavilion DV400, USB ports not working after a pw failure
You can get surge protection for your phone line I have one that is part of my broadband filter from homebase its a bit late now but worth buying to stop this happening again.
The phone line gives you a nominal 50V but when a power spike occurs this can be passed onto the PC through the phone 2000 socket that the router or modem is connected to and then can fry components with upto 500V spikes for only a few milliseconds, it is worth putting surge protection on all your electrical appliances to prevent this happening.
N.B> a plug with a fuse is not enough protection this just gives you over current and is used to protect the supply from a faulty appliance a surge is voltage which is something else. So I suggest that you connect youe entire PC to a Belkin Power Surge supply or battery backup to prevent these random surges from affecting the PC as well.
Since the USB is only 5V that is given to the device to enable it to work and will only normally blow if you connect it to a 1394 mobo socket, you could try passing the USB to the PC via a hub in the hope this may give you some protectionm but I doubt it.
Dec 22, 2008 | HP PAVILION DV4000 AND V4000 SERIES...
Power surge on hub port on my computer
Try unplugging everything from the hub and if that doesn't work then disable the hub.
You can either buy a new hub or buy a USB card. Both get the same results.
Oct 22, 2008 | E-Machines eMachines Desktop PC
go to the setup and disable usb ports.. it wd fix it...
Feb 02, 2008 | Konica Minolta DiMAGE Z10 Digital Camera
Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
May 15, 2007 | HP Deskjet 5440 InkJet Photo Printer
Intel Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
