Question about Fisher and Paykel 23 in. DS603H W Built-in Dishwasher
Tablet falls out & doesn't dissolve especially on fast cycle
New fisher & paykel dishwasher -no model num as didn't recieve manual on delivery. Tablet often coming out before end of cycle -open door at end especially of the fast cycle and find table not dissolved and fallen out of tablet space
  • 145 Answers
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Posted on Jan 23, 2009
Seriel PAA41010 dishwasher does not dissolve tablets
Tablets dissolve in the water, normally by the drawer opening and the tablet falling out into the wash. Is the door sticking (tablet door not loading door) or is the wash arm not spinning freely or blocked? These can interfere with the cycle
Nov 02, 2017 | Dishwashers
I don't know where to put the new Finish tablet in the Fisher and Paykel dishwasher. Where or what is the Dry Dispenser ?
Hello Susanna Davies,
Generally a round cap immediately next to the
washing powder dispenser...
Known as "FINISH" or "Jet Dry"... as it really does
keep spot off of your dishes & especially glassware.
Amazon com ishwasher dry agent Tools Home Improvement
I tried to look up Fisher & Paykel...
but without a specific MODEL NUMBER
I could not pull an OWNERS MANUAL to demonstrate.
look here for FREE documentation
ManualsLib Makes it easy to find manuals online
SEARS is the last place I would recommend buying parts
(but that has more to do with integrity & respect)...
Their parts, guarantees & prices are suddenly competitie
Dishwasher Detergent Dispenser Part Number 526860 Sears PartsDirect
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | Fisher and Paykel Dishwashers
I have a fairly new Fisher and Paykel double drawer dishwasher. A problem has developed all of a sudden whereby the Finish powerball tablet does not completely dissolve during the cycle (top drawer only),...
The water temperature is not coming up to the required level. The heater might be failing. Will need a technician to fix unless you are very savvy with technical repairs. Have you tried using the detergent powder in the dispenser to find if results are different.
Feb 05, 2014 | Fisher Dishwashers
Dishwasher tablet not dissolving during wash cycle
I am not sure if you can use dishwashing tablets with this model of dishwasher. These are designed mainly for powder only - you should be able to shut the detergent compartment door before starting the dishwasher.
Make sure the compartment is not blocked preventing inlet water from circulating through.
Dec 30, 2012 | Fisher and Paykel Dishwashers
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
Hi, we have soft touch washer and are having trouble with the tablet not dissolving more than ten percent.we have just bought this property and not too sure of the machines operation.can you please help...
Hello. IF you are placing the tablet in the soap dispenser, it may be that the dispenser drawer is not opening as it should. Try putting the tablet in one of the silver ware baskets and see if it dissolves. Joe
Oct 25, 2010 | Fisher and Paykel Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Detergent dispenser - Fisher Paykel dishwasher DD603
manufacture does not reccomend using tabs, small amounts of powder, will work jsut fine
Dec 25, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fischer and paykell dish washer tablet doesnt melt
if that is a drawer dishwasher ck manual i believe it it says powder only the fp drawer dishwasher doesn't use much water so desn't have a lot of spray force to dissolve tablets
Dec 13, 2008 | Washing Machines
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Fisher and Paykel 23 in. DS603H W Built-in Dishwasher Logo
1,110 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
