Question about Panasonic SC-PT660 Theater System
Panasonic SC-660 speaker problems
I have just purchased this home theater system from Circuit City. While the subwoofer and two tower speakers are working, the center and two small surround speakers are not producing any sound. I wonder if it might just be faulty wiring? Everything is correctly connected(they color coordinate, so a two year old could figure this part out), please help me!
  • girlieboop Jan 25, 2009
    Thank you so much, you saved the day! I really appreciate you helping me out, that's good kharma you know :)
The center and rear speakers are off if the PLII is disabled, make sure it is enabled by pressing the PLII button in the remote, you should see it on the display
Posted on Jan 22, 2009
SOURCE:
How to set speaker delay on Panasonic Home Theatre SC-PT960
You need to go into the Video menu of the device and select 'Speaker Settings'. See the manual available from Panasonic.
Feb 17, 2013 | Panasonic SC-PT960 Theater System with...
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
http://www.retrevo.com/support/Panasonic-SC-PT950-Home-Theater-Systems-manual/id/2869dj183/t/2/
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Feb 06, 2011 | Panasonic Audio Players & Recorders
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Static noise panasonic home theater
Simply unplug the machine for more than one minute. Then plug it back in again. That makes the system reset and the problem went away.
Sep 03, 2009 | Panasonic SC-HT700 System
SC-BT !00 Panasonic wireless speaker connection won't link
If you go into the set up menu and go to the speakers set up - it only shows the right, left, centre and subwoofer on the screen. You need to go down to the box below these speakers and activate the rear speakers which are not shown. The wireless section will then light up w1/2 on the display at the front of the scbt100 - i had to call panasonic to figure this out and they advised me it was missing from the instructions!!!
Feb 23, 2009 | Panasonic SC-BT100 Theater System
Subwoofer of Panasonic SC-DT 100 does not work
i also have same problem if anybody has solution pls let me know thanks
Dec 28, 2008 | Panasonic SC-DT100 System
Speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Dec 11, 2008 | Panasonic SC-PT660 Theater System
No sound, subwoofer or speakers
Er so you plug the speakers into anther system and they work? Blindingly obvious but there is no fault with the speakers.
Oct 06, 2007 | Panasonic SC-HT730 System
Panasonic SC-PT660 Theater System Logo
372 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
