Question about Altec Lansing 621 Computer Speakers
Altec lansing AVS 500 IC
I have Alec lansing AVS  500 4.1 speakers , There IC is damaged and completely burned down, can any one tell which IC number is used in the Woofer , so that i can buy and repair that. Please help me out , If you have a solution. Please send me a mail  rajfindme1@gmail.com
Thanks Raj
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Posted on Nov 23, 2010
Drivers for altec lansing 300 avs speakers
Hello there,
i have never seen a hard wired speaker need a driver, but with the right model number i am sure i could find a driver for it .
don't forget to Rate
Jan 26, 2011 | Altec Lansing AVS 300 Computer Speakers
Humming, how to access cct board
Try unpluging the Altec power supply turn it around and plug it ack in. It may be out of pphase with one of your other power syples.
Jan 12, 2011 | Altec Lansing AVS 500 Computer Speakers
AVS 500: The two surround speakers a re working, the other two (including the surround & volume control) are not. What could be wrong? I have tried reseating the plugs, but no change.
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 06, 2010 | Altec Lansing AVS 500 Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Altec avs500 speaker sound in 2 speaker only and not the rest
Try making sure the surround sounds knob is turned all the way to the right and that the switch on the subwoofer is on stereo and not gaming.
Mar 13, 2009 | Altec Lansing AVS 500 Computer Speakers
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
http://cgi.ebay.com/AULT-041-0001-001-18VDC-1111MA-AC-ADAPTER_W0QQitemZ6741610952QQihZ002QQcategoryZ101265QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Altec-Lansing
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing 621 Computer Speakers Logo
229 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
