Question about Toys
My brand new vmax br6008 heli have a less or near to zero farward and backward responce while flying controls r insufficient , so how it increase plz rply or guide me soon thx
  • 3 Answers
SOURCE: havoc heli frequency
You only need one frequency to be able to fly it. So it's working fine.
Posted on Jan 02, 2009
SOURCE: heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Posted on Apr 23, 2010
SOURCE: slow or no responce to throttle can not control
Run the battery out until it is completely dead and then plug in your USB cord and recharge the batteries.
Posted on Jan 13, 2011
197jacobs
  • 226 Answers
SOURCE: I have a S107G Gyro
battery need to be replace charge life is over
Posted on Aug 12, 2011
  • 30 Answers
SOURCE: hello, my air hog heli
IT SOUNDS TO ME THAT WHEN IT CRASHED YOU MAY HAVE DAMAGED THE FLYBAR OR MISSALIGNED THE PADDLES THIS WILL CAUSE IT TO VIBRATE AND MAKE IT UNSTABLE
HOPE THIS HELPS
Posted on Aug 22, 2011
My vmax br6008 doesn't fly, the lights are working but still doesn't work... please help
Hi, Anonymous I would love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information. Good luck and have a nice day.
Jan 18, 2017 | Motorcycles
Tail rotor blade is bent and helicopter wont fly forward or backwards
Fixing Your RC Helicopter - The Basics + Tips / Tricks ...
? 3:26
https://www.youtube.com/watch?v=Gxst73zE0VY
Jan 16, 2011 - Uploaded by Live2Fly94
i have a heli and the tail rotor will spin right but not left .... im having problems with my silverlit nano copter the tail ...
Frequently Asked Questions - RC Helicopter Wiki
www.rcheliwiki.com/Frequently_Asked_Questions
Probably the best way to learn to fly is to find a group of like minded people locally and ask their advice. ... The tail rotor should rotate so that the blades come 'up' towards the front of the heli. ... My helicopter won't stop spinning! ... still flying awesome but now tail vibrate and it issues backward forward. what should i do ?
Dec 28, 2015 | Toys
No power
Check the channels and make sure your on the right channel A / B usually..
give the blades a gentle turn with your fingers, they stick sometimes.
Dec 28, 2012 | FocalPrice BR6008 3.5-channel Infrared...
The helicopter does not fully charge
You mention the controller, new batteries are good for the controller, but you need to have your heli batteries to be charging correctly. If you get new heli batteries, then Check your charger, it is probably not putting out the right voltage.
e
Nov 19, 2011 | Toys
Just bought an S107G. I have brand new batteries in the controller, and the heli is fully charged. The light on this controller when turned on is solid red at all times (should be green right?) The...
Do the lights on the heli come on?
Normal start-up would be:
Turn helicopter on. Flashing light in nose should come on, as well as another blinking light (sometimes towards the rear, sometimes in the "cockpit" area) the helicopter MUST then be placed on a level stable surface until the 'other' light stops blinking, usually a couple/few seconds. This is the gyroscopes synching up and determining the "level" head orientation they will be maintaining. Then power the controller on. Making sure you're not covering the front of the controller with your hands, (the IR signals come out the front like a TV remote) push the throttle control (left joystick) up until the blades move. This what the horribly translated instructions mean by setting the helicopter and controller together.
Don't charge with the controller. It kills your controller's batteries, (which will last nearly forever if you don't use them as your heli's charger) and seems to make the birds act weird. Use the USB charger and a fully powered USB port (back of your desktop, not the front) and go by the light on the charger not an arbitrary time. Plug in charger NOT connected to heli. Look at the light. That is what the light will look like when unit is fully charged. Make sure heli is off. Plug into charger. Charge until light is fully on. If you unplug heli and the light gets brighter, it's not charged fully. A weak USB port (on a laptop or the front side data port on most desktops) may take several hours to achieve full charge. Always cool 10 mins after charging AND 10 mins after flying. Never drain fully, it will kill the Li/Po battery. Land and power off as soon as you can't maintain altitude.
If it is really charged, and you turn it on and nothing happens... no lights nothing. Then it's defective/toast. Return for refund.
These SYMA helis are awesome, and HANDS DOWN the best on the market... but they can be picky/tricky on how they are treated.
Please let me know if this helps.
PvT
Jul 27, 2011 | SYMA Toys industrial New Syma S107 Mini...
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
I bought 3 of the Syma S107 RC Heli's because it said the remote had 3 different channels. I see the Channel a,b,c on the transmitter but I don't see how I assign different channels to the 3 heli's and...
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Oct 31, 2010 | SYMA Toys industrial New Syma S107 Mini...
My son's mini air hawk 2 helicopter keeps on swaying and he can barely stop it or control it.
I found your question while searching the web for parts for my son's new, broken Air Hawk II. I also found that there are a few different mini helis marketed as "Air Hawk", so I'm not sure that my answer will apply to your machine. Mine came in a box as shown here: http://www.toygalaxy.net/2chmirche.html
OUR problem, which might be your problem too, is that the cylindrical metal weights flew off the ends of the stabilizer bar at the top of the heli. First, one came off, which threw the heli out of balance, which caused a violent shaking that probably helped the other weight to fly off. Without the weights, the stabilizer can't do its job, and the heli sways. Our temporary fix was to cut two strips of duct tape, 3/4" x 1.5" each, and wrap one strip around the outer 3/4" of each end of the stabilizer bar. This made our heli fly almost as well as it did when brand new.
The heli pictured here is almost identical to ours, and has the same weights on the stabilizer bar - these photos show what our SB looked like before the weights flew off... http://www.dhgate.com/2ch-rc-helicopter-air-wolf-co-axle-rtf-palm/k-ff808081278edf340127988dde3b153d-0.html#todescription
Hope this helps... happy flying (we can wish, right?)
Aug 20, 2010 | Toys
How do i fly my spin master air hog rc helicopter all it does is go in circles
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
