Question about Master Heaters Heating & Cooling
Red maxx rm 4000-r
Heather red maxx 4000
Meaning of the name Heather
  1. The name Heather is an English baby name. In English the meaning of the name Heather is: A flowering evergreen plant that thrives on peaty barren lands as in Scotland. Heather.
Jun 13, 2015 | Computers & Internet
Can I get a unlock code for Nokia 2320c-2b. At&T pay as you go phone. IME: 012185/00/241461/8. Thank you. email: heather.holguin.05@gmail.com
hi to purchase codes visit mobile-unlocker.com here they ask you the network name and the imei number of your mobile .finally they send you codes to unlock your mobile.
Apr 13, 2012 | Cell Phones
E maxx no reverse movment
Hi
The ESC has the ability to have reverse locked out. This is necessary because race tracks require it. Go to the Traxxas web site and download the manual. Reprogram as necessary. Good luck
May 02, 2010 | Traxxas E-maxx Evx-2 Monster Truck
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Instructions for 1987 mattel baby heather interactive doll
hi i have a baby heather and she works fine ,
hope this is some help ,
look at the back of heather
you will see two battery compartments the large1.5v box and above that a button stating grow up
press this once ist stage baby
press again goes to 1 year old
press again goes to final stage two year old
directly below the large battery compartment
two rubber buttons
one grey one red
red means enter the programme mode
the time she first says is the time set to work on
push the grey button to change hour keep doing this till you get the desired hour to match our time
press red enter button
does this quite quickly or she will say exiting program mode
heather then instructs you
on to morning wake up time
press the grey button to enter wake up time keep doing this untill you get desired wake up time
heather now knows her wake up time
press red button again for night time sleeping mode ,and follow the same steps as above till you want her sleeping time press red enter her sleep time is stored
if you press the red button again she tells you her developement status , baby 1year old or two years old , confused yet i hope this is clearer than it types
ok other functions
below her aa battery box the small thin batterys there is a switch
to the left it says off eyes closed
when switched to this the doll will switch off with her eyes closed
when switch is in the middle she s on and ready to play
when switched to off eyes open heather is switched off but her eyes remain open
still havent understood the clear round button but give me time
under her left arm if she is facing her away from you is her ticklish spot she likes that sometimes if she doesnt she will soon let you know ,
below her tummy is another sensor this is her hug sensor so if she asks for a hug gently push her tummy and she will know , heather can hear you and she will look around to hear your voice her eyes move left and right and her head turns as she working out where you are
also peek aboo if you d like to play, gently place your hand over her eyes she will respond ,
also horsey if she wants to play gently bounce her up and down and be careful these dolls can suffer from loose or detached legs ,
other tips if she doesnt have an original outfit pick one that wont restrict head movements , as for feeding , or hair brushing im working out if she does need original items or another doll item will do
have fun
russell
Nov 15, 2008 | Toys
Does not work
same problem. looking for solution(s). Got 3-4 good batches out of it, then it stopped properly freezing.
Mar 28, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
How to program RM-Y902
http://www.manualshark.org/manualshark/files/4/pdf_9380.pdf
ok i was looking over your manual for your specific tv it doesnt show that you can program this particular remote for the product listed
my suggestion is go out and by the fancy universal remote since you have the better quality tv universal remotes have a better way of programing everything together
hope this helped
Mar 24, 2008 | Sony KP-53HS30 53" Rear Projection...
Lost sound and audio
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.your choice
Jan 22, 2008 | Magellan RoadMate 700 GPS Receiver
Heating & Cooling Logo
Top Master Heaters Heating & Cooling Experts
Gil Shultz
Mike Squire
paulcarew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
