Question about Hobart Welding Tools
Plasma cutter wont cut steady
It begins to cut but it just stops and then u have to let off the trigger and start again. It only cuts for like 30 seconds. I have checked the ground numerous times and its always good
  • 56 Answers
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Posted on Jan 30, 2009
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
When you start cutting it will cut about 2 inches and kick out you let off the trigger and pull it back on it will do the same as long as you do that it will not cut continusle please advise does not...
You may need a better air supply. Also check the tip. This sometimes happens with mine when the tip gets pitted, not sure why but changing the tip sorts it out. They are fussy machines in some ways. Dont like dirty material, need a good earth.
Aug 31, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
I have a cheap chinese plasmam cutter a giant cut
Internal componet failure, return the machine for repair. Who did you purchase it from?
Jun 06, 2010 | Inverter Welding Tools
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
Plasma cutter only cuts for only a few seconds
The unit needs to be tested.
You're welcome to ship the unit to me for diagnostic testing and repair. info@taeckertindustries.com
Nov 07, 2009 | Airforce Welding Tools
Miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Mar 24, 2009 | Welding Tools
Welding Tools Logo
1,148 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
