Question about Andis T-Outliner Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it? I BOUGHT NEW BLADES FOR MY ANDIS LINER BUT IT STILL DOES NOT CUT SMOOTH AND SHARP. WHAT IS THE PROBLEM.
    Welcome Back:
    Visited the website for 2 consecutive days.
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
  • 61 Answers
The blade is fine,the problem lies in the adjustment of the blade,be sure teeth of blade are spaced open so that hair strands will fit between them when clipper is on, works perfect every time.
Posted on Jan 26, 2009
  • Rob3272 Dec 28, 2010
    What exactly do you mean by spaced open?
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
My andis trimmer is not giving a very close shave. I like to have sharp line-ups. How do I fix it? I'm not sure of the model, but I'm using the website where I bought it as reference(...
This Andis model is not very good for shaving,I purchase one before didn't do the job. I recommend The Andis GTO you can have it sharpen and adjusted to shave. check out www.mannys-sharpening.com I had purchase my Andis T-outliner service and adjust for shaving. The good thing about manny's sharpening when you purchase Andis T-Outliner he will ask you how would you like your trimmer set at' for line ups or Fade cuts or Shaving set. he resharpen the blade and make sure the trimmer is adjust power and set blade and trimmer too your request. You may pay a little more but it's worth it. Oh one more thing about his service and warranty after 3 month he gives you a free sharpening and service on the Andis trimmer you purchase from him. You only paid for return shipping. I try his service and this guy is good in sharpening and repair. I hope this was help for Tim
Nov 10, 2010 | Andis Outliner II Hair Trimmer
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
My clippers are running and the blades are moving but they are not cutting the hair
make sure it is cleaned and before putting it back together put a drop of clean oil between the blades. Also make sure it it adjusted properly.
Aug 04, 2009 | Andis 01690 Hair Trimmer
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Andis Outiliner II Trimmers
Please return your unit to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 for repairs. If the unit is less than one year old please also return a copy of your receipt with the unit and all repairs will be done at no charge. If the unit is older than one year there is a $6.50 service fee and $5.00 shipping. There may be additional charges for parts depending on what needs to be done. If you would like to speak to an Andis customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 21, 2007 | Andis Outliner II Hair Trimmer
Andis T-Outliner Hair Trimmer Logo
1,576 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
