Question about Dell Axim X51v Pocket PC
Dell Axim X51v is dead, won't even charge.
My axim won't turn on, even with a soft or hard reset. When I plug it in to charge, the power button glows green for about one second and then goes black. The first time it happened was when I plugged it in to charge, and the power button glowed red as if it was charging, but it was very faint and it continued dimming until it went completely black. Is it salvageable?
  • vrb1707 Feb 08, 2009
    I have the same problem. had the axim 51v for over 3 yrs. the amber light stays on and turns to green for a sec and back to amber. hard reset and other tips have not worked. help please
3 Suggested Answers
Rocket976
  • 31 Answers
SOURCE: dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here : http://www.microsoft.com/windowsmobile/activesync/default.mspx
Posted on Aug 05, 2007
  • 17 Answers
SOURCE: how to install windows mobile 6.5 on a dell axim
I'm starting the same thing myself. It looks complicated unless you do a lot of Pocket PC stuff. I've done a fair amount myself, but this is my 1st foray into the "cooked" ROM arena. Looks like Lenny's L14 is the best, it's wm6.5 for some technical reason I believe. MobilitySite.com has been an outstanding source of info for many of my undertakings & issues! AximSite Forum 1
Forum 2 has been rolled into MobilitySite and it was great too. Below are a few of the links I've been referring to.
Be AAAAAABSOLUTELY sure to backup your data!!! SPB backup has been great for our brood - it even lets you go cross device which you'll esentially be doing. Backup to a BLANK formatted SD card! The B/U is self extracting and very configurable both in and out. I lost a serious amount of stuff (life) when I restored & ActiveStink tried to sync my card with an empty database! My fault I'm sure, but still reeeeealy hurts. :(
Scared?? You should be, that shows you've got some common sense. Aside from data loss, you can brick your x51v if something goes wrong. That costs a bit to fix, I guess they have to physically go in and re-flash the ROM. Never tried it personally... ;)
As my good friend Miguel used to say, "GOO' LUCK FELLA!"
XcesvCmp
Cooking Downloads
Downloads (use Mega, it's faster than Rapid for me)
GOOGLE search
Posted on Oct 18, 2009
  • 17 Answers
SOURCE: i have a dell axim x51v stuck on dell logo
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
Posted on Apr 05, 2010
I forgot my password
Hi, Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device. To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
  6. THANK YOU
Dec 23, 2010 | Dell Axim X51v Pocket PC
Dell Axim X50 PDA won't turn on
try a hard reset
Dell Axim x50 / x50v / x51 / x51v:
Make sure the device is on before performing hard reset. To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-3 seconds. Release both buttons and you will see a confirmation screen asking you if you would like to clear all data in memory. To do so press the Contacts button. To cancel press the Mail button.
IT may be that the mainboard is faulty and would need to be replaced.
Aug 03, 2008 | Computers & Internet
Axim x50, buttons all work, syncs without a problem but sometimes freezes
You might need to hard reset it or update your Dell Axim x50
it is important to know if you have an x50 or a x50v. here are two vids. first one is for x50, x51. second one is for x50v, x51v.
Dell Axim x50, x51
http://www.youtube.com/watch?v=9K2P_SNTuGo
Dell Axim x50v, x51v
http://www.youtube.com/watch?v=vEDvCklrNs0&feature=fvw
Dec 15, 2009 | Dell Axim X50 Pocket PC
Dell Axim x51 v
Hard Reset
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
Sep 13, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v I made a password change and entere it into a digital rape recorder the recorder died on me and I do not remember the password as it happened 2 day after de change my cuestion is...
Hard Reset:
Do a hard reset if:
To do a hard reset:
Sep 03, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v, I does not stay operational
seems to be some problem with the battery itself. Try charging it fully and then check. Does the battery dip when the phone turns off?
Jul 08, 2009 | Dell Axim X51v Pocket PC
Set password on my dell axim X51v pocket pc and forgot it
Hard Reset -
Do a hard reset if:
To do a hard reset:
Mar 16, 2009 | Dell Axim X51v Pocket PC
Dell Axim x51v that will not power on.
Assuming the battery is not dead, try taking the battery out for a few seconds to be sure the PDA is turned all the way off. Put the battery back in and close the back. Use the stylus to hold the reset button in (on the back) while you press and hold the power button. If the battery is dead do this while it is connected to the charger. It should diplay a message telling you to press the mail button (to the left of the cursor control button) to the reset to factory defaults. Caution this will erase everything in the built in memory including any programs you installed after you recieved it.
Hope this helps
Dec 15, 2008 | Dell Axim X51v Pocket PC
Storage card
Try soft resetting the AXIM, to find the location of the reset button refer to the following website
http://tinyurl.com/56gdnd
For furthur troubleshooting refer to the following link
http://tinyurl.com/55y2vx
Thanks
Proton
Jun 18, 2008 | Dell Axim X51v Pocket PC
Forgot password
There is only one way that I know of from DELL and is performing a "Hard Reset". You will loose all your loaded programs and data loaded in Flash memory in the process:
1. With the Axim turned ON, press the Reset button until it clicks and hold it, then
2. Press the Power button, then
3. Release the Reset button, then
4. Release the Power button.
When you see the prompt on the screen, press the "Contacts" button to reset the Axim to factory defaults. You can also choose to press the "Mail" button if you need to cancel the reset process. :)
Jan 18, 2008 | Dell Axim X51v Pocket PC
Dell Axim X51v Pocket PC Logo
646 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
