Not getting display on 4p board
Smps is working cpu is working
  • 112 Answers
First the power cable, hdd cable, cd rom cable, remove ram and then add the ram, remove the agp or pci express and add it. then start the computer.
Posted on Jan 22, 2009
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
CPU fan & PSU fan working but No display coming to the screen
There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
Board specs
http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
CPU Specs
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
Double check my findings and go from there. Good Luck
Dec 11, 2012 | Gigabyte Technology gigabyte Ga-78lmt-USB3...
Intel d845gvad2,Motherboard getting on green light is coming but without ram board does not giving any beeps and processor fan and smps fan are running but does not giving any display,then which one may be...
you can try taking out CMOS battery from the board and try to reset BIOS jumper on the board. once you can also try removing and reconnecting the CPU Fan and CPU from the board.
All the best
Jun 08, 2011 | Intel Desktop Board D845GVAD2 Motherboard
My monitor has no display at all
very incomplete thread..i gotta know 1st what is ur system configuration..is all ur system is getting power on..is there any light on cabinet glowing (the power n hdd)..is there is power light coming on ur monitor..is there any sound coming out of the system..or the set is dead..??..
considering that the system gets on but u get no display and assuming that the bios has not been flashed in a wrong way..
probably itz either minor case of loose ram/improper ground/cmos battery..
or major case of faulty or defective smps/cpu/main board short/display adapter or card/monitor
..plz do check the following as in order:..
1) in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..
2) if u hv a graphics card, replace with a standby or onboard and see..
3) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
4) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
5) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
6) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
7) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
8) if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)....
always better to seek advise from ur system admin/vendor....
Nov 12, 2009 | Dell Dimension 4600 PC Desktop
No beep i had 915glvg intel mother board i had recently issued the problem no beep and no display and under cpu it is heating... ram ok smps ok mointor ok cpu ok
Hi there
It could be a memory issue, try different memory, if you still get nothing the bios is probably corrupt rendering the board useless.
Good luck and thanks for using Fixya!!
Feb 11, 2009 | Intel Motherboard
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
Booting problem
remove the ram & reinstall it again
Sep 01, 2008 | Intel D102GGC2 Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
hey
there might be problem with SMPS also. I mean there is one signal comming from SMPS - Power Good
if that singal is not comming then machine shows this kind of symtoms.
To check Power Good from SMPS -
Requirements ->
a) small wire/ pin
b) Multimeter
Procedure ->
1) Disconnect all power supplies going OUT from SMPS.
2) Locate the Orange Wire , Green Wire, Blackwire
3) Now insert small pin / wire into Black + Green wire (Make them SHORT) and provide power to SMPS --> SMPS will get started.
4) Now check the Multimeter rating for Orange wire --> it should not be less / more than 3.3 - 3.6 volts. --> If it is less / more then there is problem with your SMPS and you need to get it repaired.
5) In india it will take near about 100-150 Ruppes to repair SMPS.
alternate ->
You can replace your SMPS with other working SMPS (best option will be your friends system) and check whether same symptoms occurs or not.
Other Damedge -
If SMPS is working fine then there must be problem with FEW SMDs available on your motherboard. For this repairing in INDIA it should not cost your more than 600-700/-
May 29, 2008 | ASUS K8V-MX Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Computers & Internet Logo
David Payne
David Payne
