Question about Aervoe Tef-Lube Multi-Purpose Lubricant 16 Oz Aerosol
Where do i buy tef-lube?
What company in australia stocks tef-lube lubricant?
  • Toa Nosa
    Toa Nosa Mar 24, 2014
    Legion Oz Suppliers Pty Ltd,based in Brisbane,Sales Contact..sales@legionoz.com.au.
Legion oz suppliers,contact..sales@legionoz.com.au
Posted on Mar 24, 2014
Where can I buy replacement blade for 580 Huskylock overlocker in Brisbane?
Look on Ebay!
Cheers,
Embroidery Services
San Diego, CA
Jun 08, 2016 | Sewing Machines
Tip
Keep your locks lubed up
One of the biggest problems that people have with their locks and keys is that the lock cylinders and latches never get lubed up and the parts wear out sooner then later. About twice a year you should spray some lube into the key holes and onto the latches and all moving parts. Do this to your car as well as your house and you will limit the amount of lock/key failure that you run into. As a locksmith - I encounter problems daily that could have been avoided if the people had just used lube in their locks from time to time.<br /> there are two types of lubes that work the best - the first one is a Teflon based lubrication,, and at our shop we use TriFlow*,, I know that most locksmith shops carry this for sale to the public.<br /> the next type of lube that works good is a Silicone based lubrication, such as LPS* and this can be found at your local well stocked hardware stores or a industrial supply store.<br /> try to avoid lube sprays such as WD-40,, these may be good to clean out any dirt and debris and at first seem to lube the lock nice,, but the chemicals in WD-40 evaporate quickly and leave the locks dry and subject to wear.<br /> So take care of your locks and you will avoid the Big cost of a service call and parts replacement.<br /> <br /> c...<br /> <br />
on Feb 15, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Noisy automatic door opener, what can be used to lubricate it
Absolutely! When I had a repairman replace a broken spring, he used WD40 on hinges, rollers and the chain. Worked great. That's what I do now
Sep 17, 2014 | Wd40 Open Stock Lubricants 10110...
What are the different types of stock I can buy?
You can buy common or preferred stock. Common stock comes with the right to vote in corporate decisions. Preferred stock owners don't have the right to vote but they can dividend payments.
Aug 27, 2013 | Finance
Treadmill
Sorry, but the description does not indicate what type of machine you are looking to purchase.
Assuming it is a trealmill? Not all machines use belts which need to be lubed any more. AFG (Advanced Fitness Group) uses a belt deck combo which is pre-impregnated with lube for the estimated life of the belt. Landice does not suggest any lube for their standard home use treamills but does make Slip Coat if an additional application were needed.
Traditionally, you loosen the tension on the rear roller so you can access the laminated deck, on which the belt slides on top of. Specific to each brand or model of belt, you will apply either a wax or silicone lubricant. They are usually supplied in a single "dose" or application volume. Apply the lubricant to the deck, retension the belt and start the machine at a slow pace to evenly distribute the lube.
If you were referencing an ellitical, most manufacturers just want the track or beam to remain clean. Cleaning with a light solvent with usually remove any built up. I have found White Lightning (make) Clean Ride (model) wax based lubricant can resolve any noise a good cleaning cannot fix.
Jan 08, 2013 | Exercise & Fitness
I need to replace the bearings in the drivers side front wheel,but cant find any car shop or garage that stocks daewoo parts anymore? I've had people tell me i can use bearings from astra? Is there any...
gm dealers, motor traders stock genuine parts for these vehicles, im in australia and can get after market also from, repco, sprints, etc...or even go straight to bearing company eg. cbc bearing company, tkn, etc... depending on brand of old bearing. i suggest you try a bearing company out of phone book some have listings for vehicle applications.
Aug 04, 2010 | Daewoo Lanos Cars & Trucks
Speck Pump Model E90 has very little pressure when vaccuming pool
while I can not personally vouch for this company, they do stock speck parts.
http://www.poolpartsonline.com/m-44-speck.aspx
You will most likely need part # 2920741271 - O-RING (strainer tank) It's the o-ring that sits underneath the strainer lid and is most likely cause of your weak vac pressure. Make sure when you replace it, you use a good silicone based lube. It will help the lid seal better and prevent the o-ring from deteriorating faster if you used a petrol based lubricant.
Jun 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
Which oil is recommended for a 04 Dodge 1500 4x4
Brand names aside, both lubricants bear the same designations. 5w being how the temperature when cold affects the pour point of the lube, second # being how the lube protects components (film strength) when at operating temp. If you follow recommended oil change intervals, either will perform fairly well, and better than conventional oil. I have done extensive research on lubricants and their properties as related to professional drag race engines which see far higher pressures, temps and general "abuse" when compared to the grocery getter. The major difference between lubricants from varying manufacturers is the additive and stabilizing chemical packages they add to the actual lubricant and the quality of the "base" oil which is essentially "cloned" to produce the synthetic. This package determines the lifespan of the product, based upon burn off rate, chemical changes from shear etc. Since many auto manufacturers have increased oil change intervals, if followed, any synthetic on the market today is pretty much OK to use. Do your own research if you want to exceed manufacturers requirements. One company, Amsoil, offers some really good lubricants that exceed every requirement in every application. There are other companies that also offer some good options. The final decision is up to you, but in average driving situations, as a general rule, just about any lube that meets manufacturers posted specifications should be OK>
Jan 26, 2009 | 2004 Dodge Ram 1500
Aervoe Tef-Lube Multi-Purpose Lubricant 16 Oz Aerosol Logo
74 people viewed this question
Top Aervoe Cycling Experts
John Egan
John Egan
Are you an Aervoe Cycling Expert? Answer questions, earn points and help others
