Kenmore washer 24802, model 110.92480200, serial # cce3564876. cycling stops after wash and before rinse
This is normaly because your cold water inlet soliniode is faulty. If you want to test it set the wash temp to cold and start the machine, It should do nothing. then set it to warm or hot wash and see if it fills with water if so the cold inlet soliniode needs replacing
Posted on Jan 22, 2009
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Washer stops in rinse cycle
your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Dec 15, 2007 | Washing Machines
On any cycle you put it on including rinse/spin
Call recall # 1 800 659 7026. Give your name & telephone # you gave when you purchase it. Some CS reps want model & serial #. Your machine is probably part of the recall & will be repaired free if it is...Good luck!
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Wash cycle stops
This is a relativly simple solution... The washer probably wont spin either... Thanats due to a bad lid switch. Try replacing mthe lid switch and go from there.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Kenmore washer model 417
most time on kenmore washers any of them the lid switch goes bad you can replace it or bypass it,let me know-mike
Jun 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
256 people viewed this question
Top Washing Machines Experts
