Question about Protron PLTV-4250 42 in. LCD Television
Protron PLTV 42 IN issue
I have had this set about a year and when I turn it on the power light comes on (green), then turns orange then back to red as the power cuts back off. I read on another post where you can take the back off the tv. Is there a part I need to replace and where do you suggest to find. Any help would be greatly appreciated. I dont want to throw it out.
thanks.
  • 2 more comments
  • guitarjoem Jan 28, 2009
    I have the same issue. I was watching TV and suddenly the picture went out. I noticed the power LED switched from green to red. I've tried unplugging the TV and going direct with the cable to no avail. When I turn on/off the TV my surround sound box sees the HDMI signal change and turns on/off the audio signal as expected. The select button on the TV does nothing. I can't change modes and I have no video. When I first turn the TV on The power light goes from red to green to red and stays there. I've had this TV for less than a year and don't know what to do. I can't find my original receipt and don't wanna drop another grand on a POS TV.
  • sirving290 Jan 29, 2009
    exact same problem - but reading through some of the other issues posted here, the following makes sense:
    PEOPLE, IF YOU SET IS NOT TURNING ON BUT THE LED COMES ON, IT IS NOT YOUR POWER PLUG. YOU HAVE A BAD BOARD INTERNALLY. A SERVICER IS REQUIRED TO DETERMINE WHICH BOARD TO REPLACE.
    its likely that we'll have to discover where to locate replacement parts for this POS.
  • Anthony Gonzales May 11, 2010
    MOST OF THE NEW UNITS THAT ARE HD READY ARE BOARD LEVEL REPAIR. I WOULD SUGGEST CONTACTING PROTRON. GOOGLE IT. BOARDS CAN BE PRICY. THE ORANGE LITE IS PROBABLY AN INDICATOR AS TO WHICH BOARD THE PROBLEM IS ON.
  • THERESA ROBINSON Aug 04, 2012
    i have the exact same problem with my 42in protron PLTV-4250
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
I've taken the TV off the wall, removed the cover, cleaned the entire power supply and cleaned all the contacts on all the connectors. I then noticed while reassembling the TV that the metal chassis with all the connections on it did not fit well nor make a strong connection to its data plug.
I then pulled the cover off this chassis and carefully made sure the connector installed snugly, then I tightened the chassis in place. I then reinstalled the chassis cover.
Now the TV seems to be working without issues. It's been two weeks now and all seems well.
As I understand it, when you hit the power button the TV performs a basic diagnostic and in the event an issue is detected the TV powers off, e.g. the red/green/red LED scenario. I believe my problem was a weak connection to the interface chassis, as my TV failed intermittently for a week or so before it completely failed, prompting my above actions.
Posted on Feb 19, 2009
I have had the same problem off and on since I purchased my protron 42" lcd. I have found that if I hold the power button to the tv a little longer, I rarely have the problem. Hope this helps.
Posted on Feb 18, 2009
Protron pltv 4250 keeps shuting off
Main digital board should be checked. In most case, might need replacement. Contact any service technician.
Jun 27, 2013 | Protron PLTV-4250 42 in. LCD Television
My protron pltv-37c will turn on for 10 seconds the light turns green then goes to red after ten seconds
The green light indicates power is being applied. The change from green to red indicates that the power supply has failed
Oct 29, 2012 | Protron PLTV-32 Television
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
I have a PLTV-26... it will receive power meaning the red power light will come on on top... but when i try to hit power the screen flickers but wont come on... the light will go from green to orange......
Good day!!!!
That problem is not on the simple settings or sometime to do with the remote...
Actually that problem have 2 causes...its either power supply board or main board..
If you don't have electronic background I suggest to took it to the nearest service center on your Town..
Thanks for using fixya...
Aug 11, 2011 | Protron PLTV-32 Television
No picture/sound
power supply going bad. or went bad.
get one here. The have the best price.$60
and not $100-150.
http://www.power-on.com/lcd194-3f.html
Mar 17, 2009 | Protron PLTV-4250 42 in. LCD Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Protron PLTV-4250 42 in. LCD Television Logo
198 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
