Question about Nintendo DS Lite Console
Ds touch screen and main screen not working - connectors broken
Hi my son's ds (not lite) hinge was broken so I tried to change case - first the main connector on the circuit board where the brown flat connector to main screen has now broken (it does not hold the cable properly) so unless you hold this down powers up then switches off. But even with this held down it works but main screen is blank. Also the connector (small one of two beneath another connector nearest top of ds) is bent and keeps coming out so now the touch screen does not work either. Help? My left hinge was also broke.My brother bought a new case and tryed to replace it, and when he got done my ds was flickering on both screens, but only on the menu screen. It does not flicker on the main screen when you first turn on the ds, or on any game or, pictochat. PLEACE HELP!!!
  • Fernando Goldberg Jan 28, 2012
    Ok idk wut to suggest. :-(
$90 you robing sod
Posted on Mar 15, 2009
    Scholar:
  • 168 Answers
If you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Posted on Jan 22, 2009
Hello...i have a problem with my son's ds lite, the hinge is broken, can it be fixed?
yes check ebay for hinge axle ds lite, from what i understand their are 2 types so make sure its for ds lite, should be around £4.99 with a screw driver lol
Jan 23, 2010 | Nintendo DS Lite Console
I changed ds case all the screens work and buttons but when you touch screen with pen nothing happens
unfortunatly the ds was designed to kept in the case it came in so you'll always have problems changing the case as there are so many little things that can go wrong, in my experience your problem is either the little ribbon cable near the wireless connector is not quite in properly or the cable itself has a broken track if thats not hte problem invest in a new touch screen panel
Jan 13, 2010 | Nintendo DS Lite Console
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Jan 08, 2010 | Nintendo DS Lite Console
Ds lite top screen
Yes its fixable but it depends on what has broken.
There are two possibilities the small barrel hinge has broken, this is just a case of fitting a new one by opening the case, unscrew the light and gently pulling the top of the case away till you can change the barrel hinge.
The other one is the case has broken and is not holding the barrel hinge, can bodge it with some glue sometimes but most often you need a new case.
Jul 09, 2009 | Nintendo DS Lite Console
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Touch screen not working
Well, did you call nintendo to see if you were under warranty?
why did you try? do you have a degree in engineering? Regardless, now you have voided your warranty. Call them and see.
Jan 22, 2009 | Nintendo DS Lite Console
As far I can see with this information is that you have a connector problem. Help you with that by writing solutions would nog easy solve your problem so my advice is to find a repair service in your city that can help you out or send it to Nintendo.
Nov 27, 2008 | Nintendo DS Lite Console
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
Reseating Touch Screen Ribbon Cables
The cable for the touchscreen is one with 4 conductors that connect directly to the overlay on the face of the LCD. The flat ribbon connector on the main board is quite delicate. The three connectors for the bottom screen are on the right side of the component side of the DS phat board. The touchscreen is labeled P6. On the DS Lite, the connector is closer to the R button.
Good Luck
Jul 08, 2008 | Nintendo DS Console
Nintendo DS Lite Console Logo
664 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
