Question about Samsung Refrigerators
Manual for samsung refrigerator rf217 series
Need manual to defrost fridge
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
  • 2128 Answers
SOURCE: refrigerator keeps defrosting and depositing water in fridge.
if your food is staying cold your fridge is working fine,you probably have a blocked drain.you will find water under criper draws and maybe leaking out on floor,take off the back freezer wall and take out floor, melt out the drain and remove all the ice on freezer floor,now you have to clean out the drain,i use a steamer that you can buy for like 40 bucks,it's a shark super steamer,it will clean out all the slime that builds up in the drain line or you have to snake out the drain line with a plastic tie or something,when you think you cleaned out the line pour hot water into the drain and if the water goes down you know you unclogged it,you can buy a heater probe that installs down the drain and wraps around the heater so the line can't freeze up again,if this is not your problem you can advance the timer in the fridge side on the ceiling by turning it with a screw driver until it comes out of defrost and if it was sticking or not coming out of defrost on it's own change the timer the new part number for your timer is 2183400 hope this helps
Posted on Nov 24, 2009
  • 2468 Answers
SOURCE: refrigerator side is not cooling
the defrost grid on the evaporator coil in the refrigerator side is either bad the defrost thermostat on the coil is bad or the adaptive defrost control in the refrigerator area is bad
Posted on Aug 14, 2010
  • 117 Answers
SOURCE: SAMSUNG REFRIGERATOR RS21DANS 2 door side by side.
hello this may help
Posted on Sep 15, 2010
imufo2
  • 3773 Answers
SOURCE: Fridge is collecting water under the crisper
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
FAN ON FRIDGE NOT COOLING
Check power to the fan. It could be door switch or board
May 24, 2014 | Samsung Refrigerators
Have a Samsung RF217 Refrigerator that is collecting water in the right vegetable bin? Fridge does not have ice maker.
Just had mine repaired. The evaporator drain is plugged with ice. The solution is to replace the heat sensor and add a piece of metal extending from the small heat coil under the evaporator that supplements the piece already there. The guy that repaired mine used a piece of coat hanger wire for the extension. Except for the heat sensor, it's a repair anyone can do. Just take off the plastic cover on the inside back of the fridge, melt the ice obstruction in the drain and hang a piece of wire from the heat coil into the drain. He also used some metallic duct tape to raise the height of the drain tray on the ends so that it wouldn't overflow in the future.
Jul 01, 2012 | Samsung RF217ACBP
Fridge is collecting water under the crisper drawer of my Samsung RF217 fridge, has french doors and bottom freezer. How do I get to the drain hose to thaw/flush it?
Leo Ponder
imufo2
Aug 16, 2011 | Samsung Refrigerators
FRIG NOT COOLING - FREEZER IS FINE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 27, 2011 | Samsung Refrigerators
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Samsung Refrigerator top and bottom Coil Iced Up
You have a bad defrost timer or a bad defrost heater.
Aug 05, 2009 | Samsung Refrigerators
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
My refrigerator is warm and ice build up is happening in the fridge
There is a timer that controls the refrigerator defrost cycles. This is located behind the kick panel at the bottom of the refrigerator. Remove the panel and look for a dial-like device toward the front. Try to manually turn the timer dial and listen for an audible click. No click, no defrost. Call a NEW repairman and have him check the defrost timer. Hope this helps.
Jul 27, 2007 | Samsung RB1955 Bottom Freezer Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
