Question about KitchenAid Superba KUDE40FX Fully Integrated Dishwasher with 5 Wash Cycles, 6 Options, EQ Wash System, ProScrub Option, ProWash Cycle, Culinary Caddy Utensil Basket and Whisper Quiet 46 dBA Sound Insulation System
Brand new KitchenAid KUDE40FX door won't latch any more and thus won't start.
Was working fine.
  • KitchenAid Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Posted on Jan 11, 2013
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Posted on Jun 12, 2009
SOURCE: KitchenAid KUDSO1FLSS5 - door pops open
I am an experienced techician and have tried all these solutions in the past sometimes at no avail. But replacing the tub which has a limited lifetime warranty along with hinge arms will solve the issue. This has such a margional clearance I can never see anything visible causing the door to pop open
Posted on Sep 18, 2011
  • 107 Answers
SOURCE: door won't stay latched on dishwasher
Make sure nothing is binding the racks which could be pressing against the door when closed. Also make sure the dishwasher isn't installed too tightly in its place, which puts pressure on the latch. You may need to lower the leveling legs a bit.
Posted on Oct 25, 2011
  • 403 Answers
SOURCE: kudsolflss2 dishwasher won't latch
you will need to replace the strike and the catch. you can try adjusting it but that probably will not work
Posted on Nov 27, 2011
02 Jetta trunk latch fix
Yeah, you have a bad spring. You will have to buy a whole new or used latch. I wouldn\'t try taking the latch apart as some times they are riveted together and would be almost impossible to reassemble. Be careful, Jettas are tricky to work on.
May 20, 2013 | Vehicle Parts & Accessories
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
Door won't open from inside '98 silverado
your door rod to your latch must have popped off your inside door latch. take your door pannel off and the door rood will be unhooked
Dec 12, 2012 | 1998 Chevrolet Chevrolet silverado
Washing machine won't start
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
Oct 14, 2012 | Kenmore Washing Machines
Door won't lock
If your dishwasher door won't lock, it could be a problem with the latch adjustment or the door seal. Some latches are designed to be adjustable, and yours may be set too tightly. Look at the owner's manual for specific instructions or follow these basic steps for adjusting the latch:
1. Spray WD-40 or other lubricant onto the latch.
2. Slowly open and close the door several times, noticing whether the door hits the strike plate (the metal plate on the top of the dishwasher frame). Use a hammer to lightly tap the strike plate to move it as needed.
3. If possible, adjust the depth of your latch by unscrewing the latch assembly using a screwdriver and reseating it. Work with the adjustment until it latches correctly.
Note: If your latch is permanently fixed, have a qualified professional address the problem.
The door seal-also called a gasket-can also cause problems if you have a brand new dishwasher or door seal. The good news is that the door seal will mold to the door's shape over the first week or so. Operating your dishwasher with the highest level of heat will help this process happen more quickly. Because the material is pliable, and because heat will soften it, it will seal to the door more securely after those first few loads.
On the flip side, an old door seal can also keep your door from closing correctly. Check the seal for signs of warping or damage. If the seal needs replacing, arrange for service, or consider doing it yourself. In most models, it's a relatively easy DIY project. See Dishwasher gasket replacement for step-by-step instructions.
For more troubleshooting steps, see Dishwasher door repair. I hope this helps!
Oct 08, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
How to start kitchenaid dishwasher
1-confirm power make sure breaker is not tripped or fuse is good and no tripped GFI's (no power obviously it won't work) 2-confirm water is on (the timer has a delay that it powers down during it's wait for the unit to fill with water 3-make sure the door is fully closed and latched properly (the door has a safety interlock to prevent the dishwasher from operating while the door is open -- think water sprayed everywhere) 4- beyond this if it is a new install and has never worked call your installer back
Apr 08, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Brand new kitchenaid dishwasher won't stop beeping when you push the start button. Then evenly shuts off.
Hello, Thank You for using FixYa. I will be helping you today.On some models you only have 3 seconds to press start and close the door. Try that and see if it works.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Dishwashers
KitchenAid KUDI10FL dishwasher- The door spring system broke and I repaired it, but now all of the sudden the dishwasher will not start. The door may have been dropped a couple of time before the spring...
Hi- It is possible that the door latch is not completely engaging. If the door dropped the hinges may have bent a little thus preventing a good contact with door switch. Try pressing and holding the door shut, hard, and pressing start. If that works then replace the latch assembly. It is also possible the membrane switch got rattled with the door falling, or a wire is grounding out somewhere. Hopefully it is just the latch. Hope this helps, good luck.
Sep 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid Superba KUDE40FX Fully Integrated Dishwasher with 5 Wash Cycles, 6 Options, EQ Wash System, ProScrub Option, ProWash Cycle, Culinary Caddy Utensil Basket and Whisper Quiet 46 dBA Sound Insulation System Logo
310 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
