Question about Brother MFC 7360N - Multifunction fax / copier / - MFC-7360N-US
Brother 7360 all in one will not collate while copying
How to fix faded copying on brother mfc7360
Gradual fading, going from dark to light or vice versa, is usually caused by unequal toner distribution. Just remove the toner cartridge and shake it by rotating 45 degrees to one side along its axis and then back to zero and then the other direction. It's ok for the cartridge to leak a little amount of toner, so it's recommended to use plastic gloves and do it over an old newspaper to avoid smearing toner all over.
Oct 23, 2016 | Brother Mfc-7360
I have a MFC7860DW, How do I set it to collate copies?
You can download the manual from here: Reference page 24: "Collate With the Collate check box selected, one complete copy of your document will be printed and then repeated for the number of copies you selected. If the Collate check box is not selected, then each page will be printed for all the copies selected before the next page of the document is printed."
Mar 02, 2015 | Brother MFC-7860DW Compact Wireless...
Do the tone cartridge time out?
Hi, if the above suggestions dont help it may be out of toner. according to your dates and numbers. average 17.5 copies per day. you purchased it approx..300 days ago. = 5,250 total copies !?
Jun 06, 2014 | Brother MFC7360N AllInOne Laser Printer
How to reset brother j125 printer's ink absorber full
Go To Below official brother Printer Page For Your problem http://forum.testcopy.net/threads/how-to-reset-toner-cartridge-reset-counter-for-brother-mfc-7360-printer.1915/ Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
May 04, 2014 | Brother DCP-J125 Inkjet Multifunction...
Collate copies
The control to collate printing is in the driver. If your machine is equipped with an output tray that will offset sort the sets then they will be staggered otherwise they will be in one stack.
This machine does not collate while copying. Dah...shame on Xerox!
Jan 06, 2010 | Xerox DocuColor 12 Printer
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
I am running Microsoft Word 2003 and have an HP 1320n printer. My problem is that when I print more than 1 copy the pages do not collate even if the collate box is ticked in the print dialogue book and so...
HP 1320 print driver is a universal print driver covering several printer models.  Collating only works on HP printers if you have a multiple exit tray system for commercial based laser printers similar to finishers on a copier.  They have to have room to keep the copier together before they can be collated.  On a standard configured 1320 there lacks any space for finishing tasks.
This support bulletin on hp.com can provide you the answer:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01366409/c01366409.pdf
Sep 10, 2008 | HP Computers & Internet
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Brother MFC 7360N - Multifunction  fax / copier / - MFC-7360N-US Logo
189 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
