Question about Motorola Mobility Bluetooth Headset H3 for Razr Headset
My bluetooth won't turn on
My bluetooth is acting very wierd. it will light up when it's charging but when i try to turn it on it won't turn on. it has been fully charged it just won't turn on.
  • DrMary Jan 27, 2008
    I have the same problem with 2 of them. I think that the button to turn it on is not connectincg with the switch inside but how do you fix that?
  • 7 Answers
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Posted on Feb 04, 2008
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Posted on Aug 28, 2008
abhishek33
  • 1239 Answers
SOURCE: charging bluetooth
hi sir..
please do u have muiltimeter just verify whether the voltage is there ..
Posted on Sep 02, 2008
SOURCE: plantronics bluetooth won't turn on
me to i charge it one night and now it will not power up!
I put it back on the charger light turns red and then goes out!
Posted on Nov 06, 2008
jmgldsmth
  • 2005 Answers
SOURCE: The Motorola H800 bluetooth headset doesn't charge or turn on. While charging it just displays blinking green light
open and, replace the rechargeable batteries
Posted on May 29, 2009
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
Jun 21, 2012 | 1995 GMC Sonoma
I have a 2004 mazda 6 the car jumps from 1st gear to 3rd and the battery light comes on what can it be
If the battery light is on you alternator is not charging.
Check that first , as for the trany , when voltage drops below minimum requirement , computers may act up wierd.
Jun 30, 2010 | 2004 Mazda 6
Bluetooth has lost connection with phone and I can't get it back
You should delete the headset from the "paired devices" list on the phone and completely redo the pairing process, it sounds like the two have gotten into some kind of wierd state.
If you need help with this please include the make and model of your phone.
Feb 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My 91 integra electrical system/ignition is acting up.
SOUNDS LIKE STARTER CABLES ARE IN NEED OF CLEAN AND TIGHTEN AND SOLENOID STICKING. NEXT TIME IT HAPPENS GIVE THE SOLENOID A FEW TAPS WITH A HAMMER IF POSS AND TRY AGAIN
Apr 14, 2017 | 1991 Acura Integra Hatchback
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Bluetooth not charging
The internal battery is bad or your charger is faulty, got a kink in the cord.
Jan 22, 2008 | Motorola Mobility H700 Wireless Headset
My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 | Cell Phones
Open Questions:
Motorola Mobility Bluetooth Headset H3 for Razr Headset Logo
2,715 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
