Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Red shadow on all images
I have a JVC 48WP74 HDTC rear projection that is about 4-5 years old. I bought it used. We moved it into my apartment. Worked fine for about a month. Then all of a sudden, I have like a red tint or shadow for all the images on the screen. I talked to a local technician and he said I needed a new convergence switchboard. He said it would run me about $300-350+ for the parts and labor. But, doing my research it sounds like I can mess with the convergence to line the red bulb back up? I don't know. I have no expierence with tvs but just reading through other similar problems and possible solutions, that could be an option rather than spending 350 on a part when I bought the tv for 300. Any solutions?
  • nbhamil Jan 23, 2009
    actually I have a AV-48WP34. That is the model number. Do you think I need the same parts. With this red shadow, which usually a shadow that is off a bit ( usually down and to right) does that mean I need to adjust something that may have got knocked loose or will replacing the covergence ICs (STK392-110) and feed resistors? and JVC convergence resistor kit #1 take me back to the picture I used to have before the screw up.
    thanks
  • JVC Master
  • 8,617 Answers
You will need to cahnge the Convergence Ics for sure and possibly the feed resistors. You will need two STK392-110 Convergence ICs and 1 JVC convergence resistor Kit #1 you can get the parts at the following link with free installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2009
  • Sonny Berry
    Sonny Berry Jan 23, 2009
    your model is the same as the AV48WP30 so you can actually order just the AV48WP30 convergence repair kit as that contains both ICs and all the resistors in one kit. Its actually cheaper than buying the two Ics and then a resistor kit since you dont have the WP74 series.
Red rainbow on top half of screen and double images
ch the stk 392-120 try to set the conv.or try to auto set conv. if work then ok if not work you and stk392-120 or 150 you need a sevice man for that.
Jun 02, 2009 | JVC AV-48WP30 48" Rear Projection...
Seeing double
You need to replace the convergence board in your tv .
Also you have mentioned it is 5 years old so its time to replace it .
But it will not be cost effective one .
SAM ANDERSON
Sep 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Pictures have a green shadow on all images
Remove front grill and chip board ,there are three knobs one is for brightness I think another for a sharper picture (best to use while convergance adjustment and the third which should balance your
black or white screen to have blue,red, or green tinge ,you like to have it as neutraul as possable.
if you are stll getting everything in blue,green or b-52 agua marine ,your red lamp may be burnt out!.
Feb 05, 2009 | JVC AV-48WP74 48" Rear Projection...
Picture shadowing and waving pictures
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 19, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30: CONVERGENCE PROBLEM!!! HELP!!!
U have convergence board issues. Sometimes over time the solder joints on the board go bad or develop minute breaks. U might try removing the board and resoldering every thing you can get it. U can also consider baking the board in an oven at around 270 degrees for about 8 minutes to melt all of the connections on the bottom of board.
Then remove, allow to cool, cross your fingers and see what happens.
May 05, 2017 | JVC AV-48WP74 48" Rear Projection...
Re: I art jvc
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
Aug 14, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48 IN
You will need two STK 392-110 ICs. They are located in the front of the TV. remove the speaker grille and then the small access panel and you will see the convergence board it has two Black heat sinks the ICs are mounted there. You can get replacement ICs with free shipping and free instalation instructions at the following Link.
Jun 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
Colour problem in jvc
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | JVC AV-48WP74 48" Rear Projection...
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
