Question about Echo Gas Blower 185 MPH 900 CFM Blower PB620ST
Need spark plug gap for echo blower - Echo Gas Blower 185 MPH 900 CFM Blower PB620ST
  • 5 Answers
SOURCE: Echo Blower dies out when full throttle
Find the fuel air mixture screw located by the carb and turn it so the moter starts to slow down then turn it so the blower runs smoothly this should keep it from dying out
Posted on Nov 23, 2008
  • 603 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
Posted on Apr 06, 2009
mowerman1857
  • 389 Answers
SOURCE: ECHO PB-650 Spark plug gap size
20 thousandths
Posted on Sep 16, 2009
Testimonial: "Thanks just what I needed great result thanks again"
#1 Taper
  • 1040 Answers
SOURCE: ho spark on a pb 403t backpack blower
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
Posted on Nov 30, 2009
  • 223 Answers
SOURCE: Need the air gap between
All magnetos work best with minimal air gap. Gap it with the thinnest piece of paper/plastic that you can remove from the gap. Spin it, examine flywheel for evidence of rubbing. If it's good, start it and zoom it a couple of times, shut it down and check again.
lp
Posted on Feb 05, 2011
Spark plug gap
Most 2 cycle products it should be 0.025
Oct 24, 2016 | Echo Garden
No fire on echo pb200 leaf blower
I would check to see if the spark plug is firing first off and if it is ok check the plug wire and make sure there is no damage to it. If that is ok then you probably have a bad coil. You can use a spark plug tester and see if you are getting fire from the coil if not you will need to replace it. If you change the coil be sure to note the air gap between the coil and the flywheel then set the new one to approx. the same distance. Hope this helps.
Sep 29, 2016 | Echo Garden
Spark plug gap for echo pb403t backpack blower
.028 but between .025 ~ .030 is ok
NGK BPM8Y
Apr 26, 2015 | Echo Garden
Spark plug gap for pb1000 ser number 413707
NGK BPM(R)-7A 0.65 mm (0.026 in.)
Feb 14, 2015 | Echo Garden
Spark plug gap size for 02 toyota echo
Spark plug gap size for 02 toyota echo?
NGK BKR5EY Spark Plug Gap: .031 inches or .8mm
Feb 08, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Pb-460 no spark
u could have a bad magneto, or u may need to check the gap on the magneto and the gap on your plug. pull plug and insert plug into wire and rest on top of head an pull starter to see if u get spark. if not, u need to check your magnetos gap.
Nov 04, 2012 | Echo Pb403 Pb413 Pb460 Pb4600 Carburetor...
What is the spark plug gap for an echo pb200 leaf blower? '
All echo gaps you can use a book of matches work fine....
Sep 10, 2012 | Garden
Echo Gas Blower 185 MPH 900 CFM Blower PB620ST Logo
19 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
