Question about Magellan Roadmate 2120T-LM GPS Vehicle Navigation System
2120t feature codes?
Is there any feature codes for this unit other then DEMO
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
I have alpine cda 9851can't get the demo off
try reset 1st its a tiny hole above the rotary knob.
see page 17
Demonstration
DEMO ON / DEMO OFF (Initial setting)
This unit has a demonstration feature for the display and sound.
• To quit Demo mode, set to DEMO OFF.
http://a248.e.akamai.net/pix.crutchfield.com/manuals/500/500cda9851.pdf
May 03, 2015 | Alpine Car Audio & Video
I turn the unit off and in about 6 seconds, it turns itself back on. In order to keep it turned off, I have to unplug the unit.
Look on the front panel or remote for a button labeled "DEMO". The unit is probably not turning fully back on, but going into a demo mode that scrolls features across the front display.
Jan 31, 2013 | Panasonic SC-AK18 CD Shelf System
I have panasonic tv tc-2120t i want univesal remote code
Universal remote codes for Panasonic TVs are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070. Check this for more codes and other details to different remote controls.
Jan 02, 2013 | Televison & Video
Control demo
Hello - If the unit was in demo mode it would not produce any water or rinse actions. So if you have water entering the unit, I doubt it is at all in demo mode. Error E01 for Electrolux models means the unit has detected a water leak. This will need to be checked and a repair performed by a technician since they will need to repair the leak and retest unit.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
STR-DE845 Stuck in Demo mode, tried the power and ...
To get the STR-DE845 ( or STR-DE945 ) out of DEMO MODE - Turn unit on and HOLD POWER BUTTON FOR A FEW SECONDS ...Turn unit off and when you turn it on again it should be reset ...It worked for me.
( Note : You may need to do this procedure before it goes into its actual demonstration of features ... Press and hold the power button immediately when it initially starts scrolling it's DEMONSTRATION MODE message . )
May 12, 2010 | Audio Players & Recorders
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
While the unit is on:
Press and hold [–DEMO] until “NO DEMO” is
displayed.
Each time you press and hold the button:
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
I HAVE A DEH-P640 AND THE SCREEN IS IN DEMO MODE AND I WOULD LIKE TO KNOW HOW TO TURN IT OFF IT IS VERY ANNOYING DRIVING AT NIGHT THANKS RON
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
Notes
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 27, 2009 | Car Audio & Video
HI,I INSTALLED MY DEH-6500 PIONEER RADIO,CAME ON DEMO MODE,PUT CD IN VOLUME WORKS BUT CANT CHANGE SONG ON CD,TOOK CD OUT,BACK TO DEMO MODE WHERE I CANT DO ANYTHING,CAN YOU HELP GET ME OUT OF DEMO MODE...
Feature demo
Notes
Apr 26, 2009 | Car Audio & Video
Garmin streetpilot 2620 in demo mode
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
Nov 12, 2008 | Garmin StreetPilot 2620 GPS Receiver
Magellan Roadmate 2120T-LM GPS Vehicle Navigation System Logo
100 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
