Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Freezer side not freezing
Ref side works fine but freezer about every third day temp above freezing
  • 198 Answers
It appears that the defrost bi metal control is hanging up and during the defrost the temp in the freezer is going too high. It is supposed to terminate the defrost at around 50 degrees. This usually occurs in about 20 minutes, if the defrost heater stays on for too long the freezer temp goes too high. Change the defrost bi metal
Posted on Jan 24, 2009
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
My Kitchenaid refrigerator is not cooling well. The meat in the bottom is freezing and the air inlet next to the meat is freezing over with ice. The top portion of the fridge is not cooling, though. The...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 24, 2011 | KitchenAid KSSC48QMS Side by Side...
Frigidaire side-by-side water & ice in the door Model #GLRS234ZAW1. The refrigerator side freezes with its thermostat any where above the lowest setting. Also the freezer thermostat has to be only a...
Leo Ponder
imufo2
Sep 22, 2011 | Refrigerators
Make/Model: GE GSS25XPGDWW SN: MH434185 4 year old side-by-side fridge is freezing bottom food compartment, not freezing freezer compartment and water stops working. No problem with icemaker. Works...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 16, 2011 | GE Refrigerators
Samsung ref model RB2044SL freezer works fine refridgerator side has no light and no temp cooling like the refridgerator side lost all power beeping constantly power freeze and everything on freezer side...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 06, 2011 | Samsung Refrigerators
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidaire refrigerator
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
155 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
