Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
No USB mode in Settings menu c250
I bought a used c250. No manual. Am trying to update firmware or whatever because can't download audiobooks from my local library (which is why purchased unit) and everyone on this site says change mode. My Settings menu does not have a USB Mode or Mode option. I've got Equalizer, Power, Display, Language, FM Settings, Volume, System Info, Reset All, Format. Help!
  • Anonymous Jan 23, 2009
    I have the exact same problem. Curious to see what the solution is. it is version 01.01.05P if that helps.
  • Christine Feb 14, 2009
    Tarah34, I'm sorry, I am not good with computers. Device is attached to computer, open up Windows Media Player, and nothing seems to happen regarding an update. Can you be a little more specific? I would greatly appreciate it.
I had the same problem. Firmware updater would not work because player was 'stuck' in MTP mode and displayed no USB menu option because of firmware update 01.01.05P. The way I updated my firmware to version 01.01.07P was by using Windows Media Player, which is designed to interface to the player in MTP mode. After doing that (Media Player prompts the user on updating firmware plus you have the option to install the user manual), the USB menu option became visible and functional, and I was able to select MSC mode.
Posted on Feb 08, 2009
    Problem Solver:
  • 8 Answers
Updating firmware video
http://www.youtube.com/watch?v=kVLoG4FWEjc
Posted on Jan 25, 2009
I don't know if it is my computer or my Sansa, but I plugged it into the USB drive, and it says that it cannot install the player. I might have to download some software or something, but I have no idea.
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Dec 23, 2010 | SanDisk Sansa e250 MP3 Player
When i power it up it is reading at the top of the screen load main image failed switch to recovery mode then it just freezes
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......recovery mode lock the sansa hold center button in and push and hold the start/menu button until recovery mode....Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Dec 21, 2010 | SanDisk Sansa e260 MP3 Player
My mp3 is froze and i tried to reset but it want
hold the switch for 15 seconds. the same thing just happened to me.
Dec 22, 2009 | SanDisk Sansa Fuze MP3 Player
The PC will no longer recognize it. I've tried downloading the driver from the sansa website and manually attempting to fix it will no vail
Support for the Sansa Clip support information is on next site:
http://kb.sandisk.com/app/answers/detail/a_id/4303/kw/clip/r_id/101834
Correct link for updating the Clip's firmware:
http://kb.sandisk.com/app/answers/detail/a_id/300/related/1
When MANUALLY installing firmware:
Check the version of your player to have the matching firmware download for the player, as described in the updating firmware link.
Going to the Sandisk forum site for the Clip firmware download:
http://forums.sandisk.com/sansa/board/message?board.id=clip&thread.id=15109
Note: read the instructions how to perform the firmware update.
1. Choose the correct version for the player.
2. Connection mode in Windows should be automatic, when not recognized in Windows or with MAC and Linux use MSC mode ***** .
3. Extract the zip file on the computer first.
4. Next put the unzipped file on the player in the root directory.
5. Disconnect the player.
6. Restart the player: the firmware update should restart now.
*****Note:
Switching to MSC mode for Sansa Clip:
Method 1: through the menu
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Method 2: forcing, using the buttons / switches
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
Need more help ? Just post a comment.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
How do i get the driver of the mp3 so that it gets recognized on my computer?
Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Oct 26, 2009 | SanDisk Sansa e260 MP3 Player
How to put music in a sandisk sansa
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
You can make another music folder (music1)put music in this....
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
I was trying to download the sansa media converter so could put pictures on my sansa e260 and im getting an eror installing iKernal.exe(0xa00) not sure how to continue
Sansa latest updates
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
Unable to download anything SanDisk c250
In order for you to resolve the problem you are having, you will have to update the firmware on the device...This is a common problem whenever the device firmware is corrupted...To download the device firmware you need to go to site below....
http://sandisk.com/Retail/Default.aspx?CatID=1376
And also you need to check the device USB mode under setting...It has to be under MTP mode or auto...should you need any other assistance please contact me or you can call call sandisk1.gif at 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Feb 08, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
183 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
