Question about Altusen Aten MasterView CS1764 4-port KVM Switch
Aten Master View KVME CS1774 Wavy Screen
I have a 'wavy' screen on some PCs using this device, I've switched from a CS 84A, and no matter what I do to the resolution, or frequency, some outputs are ok, others have a 'wavy' appearence.
  • Steven Fitzgerald Jul 10, 2007
    Fantastic!
    Thanks so much for that, I changed the Monitor cable to a better quality, and it solved the problem!
  • 624 Answers
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Posted on Jul 05, 2007
Is this a MS-7184 problem? My son's computer has a wavy screen, so I replaced the CRT monitor with a new flat screen. Still wavy. Next, I replaced the onboard video card with a PCI card and nothing shows...
you need to install drivers with the new video card but first you must uninstall the old one-definately a driver issue(assuming all cables are good,etc)
Sep 15, 2009 | HP Compaq Presario SR1620NX...
Toshiba 50H82 with wavy lines at the top when in HD mode
Found this person on eBay who repairs the hyperboard for $75 quickly with very positive feedback.
http://myworld.ebay.com/kcarrigan/
I have the same problem and will probably send mine after the holidays.
Dec 03, 2008 | Toshiba 50H82 50" Rear Projection...
Hitachi Projection Color Lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 24, 2007 | Televison & Video
Wavy lines
KIT10 $29.50
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Wavy line
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 25, 2007 | Toshiba 50H72 50" Rear Projection...
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Wavy lines in display
this sounds like screen drive problem, solder around flyback pins and ground.
Aug 25, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Altusen Aten MasterView CS1764 4-port KVM Switch Logo
320 people viewed this question
Top Altusen Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
