Question about D-Link Network DIR651 Wireless N 300 Gigabit Router Retail 1 Push Button 2 External Antennas (110689B22
On a dlink dir651 how do I switch to 5ghz operation?
The tablet "Teclast X16 Pro" has a very bad WLAN Connection. My Mobilfone (10 cm near Teclast tablet) has a typical download rate >45 Mbit, Teclast below 11 Mbit.
I believe that this wireless radio operates in the 2.4Ghz range, so I would recommend trying to have it in a "line of sight" to the wireless access point if possible. If you have the ability to change it to the 5Ghz range/connect to a 5Ghz SSID you should do so. This will cut down on the interference from metal and other structures.
You can download a Wifi analyzer app for your phone that should help you determine what you have in the 5Ghz range if anything, and what the SSID is.
Dec 28, 2016 | Computers & Internet
How do I switch to a 5ghz WiFi signal on my next book area 8 premium edition with 802.11 b/g/n
It is not possible to connect your PC to 5 GHz network. Its wireless card has no capability for 5 GHz band. See this answer for similar question:
Get 5Ghz on laptop
You can buy additional Wi-Fi adapter supporting 802.11a/b/g/n or 802.11ac standard.
Dual band adapter example is here:
WiFi AC Adapter Dongle GMYLE Wireless AC1200 Dual Band 802 11ac USB3 0 866...
Jan 27, 2016 | Computers & Internet
F7D8302V1 is only broadcasting the 2.4ghz Wireless G SSID (SSID = Belkin.5d94 ) The 5ghz Wireless N SSID is set to "MyTV". This SSID doesn't show up as broadcasting on any devices...
This might not actually be an issue. The 5ghz band is not available on a lot of devices. Unless your device says it supports 5ghz, you will not see it. All cell phones I know of, blackberry's, iphones, etc... use wireless G, or N 2.4ghz. New devices like HD streaming video players, media extenders, 2010-2011 MAC's and some new PC laptops support the 5ghz band. Your configuration screen shot looks fine. Verify that your devices support 5ghz.
My MAC book PRo 2011 supports 5ghz and so does my Asus Laptop. These two devices connect to the 5ghz and all my other devices, including my blackberry, connect to 2.4ghz.
Regards, Chris
Jul 01, 2011 | Belkin (F5D7231-4) Wireless Router
Hey how do you up a 2.4/5 ghz dual band router up to 5ghz? I just bought this and my ps3 is still laggy.
You need to beware that 5Ghz may not be supported by your PS3, as this is not a wireless standard.
Wireless Standards are a,b,g & n
You probably should either relocated the router so its not obstructed by brick walls or metal objects.
Otherwise you can try move the PS3.
Mar 03, 2011 | D-Link DIR-615 Wireless Router
I have a D-Link DIR-628 2.4GHz/5GHz router, and I need help in switching from 2.4 GHz to the 5GHz frequency. Can anyone help me with this?
Hi Randy,
The easiest way is to go to the Setup menu (Top menu) -> Wireless Settings (Left side menu) and change the setting from 2.4 GHz to 5GHz with a radio button.
You can also download the manual from D-link (here). Look at page 29 - there is a description with a screen shot.
If you need help with accessing your router's interface, just come back here and leave a comment - I'm happy to help.
(Or check the manual...;-)
Jan 15, 2011 | Computers & Internet
How do i turn my router from 2ghz to 5ghz?
Select 2.4GHz if you want to use the 2.4GHz band or 5GHz band if you want to use the 5GHz band.
The product Manual is located here:
http://www.dlink.com/products/default.aspx?pid=DIR-628&tab=3
(Page 29)
Dec 22, 2010 | D-Link DIR-628 Wireless Router
How do I switch my DIR-628 router from 2.4 GHz to 5GHz
Open the router's setup page through http://192.168.0.1 and look under the Wireless Tab. You'll see the there the radio band which is 2.4 and 5Ghz
Jul 03, 2009 | Computers & Internet
How do I switch from 2.4GHz to 5GHz on a D-Link DIR-628 router?
Usually your device and router selects the the 2.4 or 5.8 band for the best reception.
Apr 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
What is the channel on the router setup on a netgear MR814
Hi matty,
Are you asking what radio frequency the Netgear MR814 operates in?
That would be the 802.11b standard 2.4GHz.  It is the same as some cordless phones which operate in 2.4GHz so beware interference.  You may want to opt for a 5GHz 802.11g router or a cordless phone that operates in the 5GHz range.
Mar 12, 2009 | NetGear MR814 Wireless Router
How do i change from 2.4GHz to 5GHz
not sure how to change it from 2.4GHz to 5 GHz but I know the 802.11a = 5GHz
802.11b and g are 2.4GHz
and the 802.11 can be both 2.4 or 5GHz the information from master JC is not correct if i'm not mistaken
Oct 29, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link Network DIR651 Wireless N 300 Gigabit Router Retail 1 Push Button 2 External Antennas (110689B22 Logo
52 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
