Electrolux Kelvinator Air Conditioner ESE24HRA 4 BLINKING LIGHTS AND TURNING OFF
4 BLINKING LIGHTS ON FRONT PANEL AND TURNING OFF?
bluenadas
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
  • 121 Answers
SOURCE: kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
SOURCE: Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
Posted on Jun 13, 2010
hvac1960
  • 2133 Answers
SOURCE: Kelvinator split- type room air
E-9 means high or low pressure. Please service your unit and then check. May be sometime problem would have solved. If not, check fan speed. If less rpm change new capacitor. Thanks.
Posted on Dec 27, 2010
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Kelvinator window air conditioner repair
it can damage the motor solenoid. looks similar to these
motorwiring-cjpkdpr3r0ttdxwtzkam4apy-1-0.jpgpower goes into the capacitor and turns the motor on at a steady speed and builds up power, if it overloads that can happen it will either send full voltage that the motor cannot build up on or no voltage
Feb 22, 2018 | Electrolux Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Where can I download the user guide for a Kelvinator 6711A20013U air conditioner?
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Is it helpful?
Dec 26, 2010 | Electrolux Heating & Cooling
All lights blinking - doesn't turn on
Try turning the power ot the unit off for a few minutes and then back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Amana PTH123B25AJ Heat Pump Air...
Electrolux Kelvinator - Unit on defrost
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different...
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Jul 14, 2009 | Electrolux Heating & Cooling
Heating & Cooling Logo
312 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
