Question about Kenmore Dryers
Kenmore dryer 62932 wont heat
Our dryer will not heat, is it similar to another model number or another brand that is easier to find a parts diagram?
    Problem Solver:
  • 18 Answers
Repairclinic.com has a comprehensive parts diagram for almost any machine. A dryer with no heat is a very common problem, there are several thermostats and safety cutoffs that can make dryers not heat. Thankfully they are reletivly easy to diagnose. All you need are some basic hand tools and most important, an ohm meter. Most of the time all the thermostats will be in one section of the cabinet (top, bottom, back) to test them, make sure the power is OFF, unplug the wires from the thermostat(s) and put one lead of the ohm meter on each connector, if it shows anything put 'ol' or open line, your thermostat should be good. Keep going until you find the faulty one. If all thermostats test good, try testing the element(s). the element is tested in the same manner as the thermostats, if it tests bad, replace it and enjoy doing laundry!!
Posted on Jan 22, 2009
Where is the heating element on model # 86873100 Kenmore Electric Dryer Model # 86873100 68731 Serial # M 94966314
Here is the Sears parts site with diagrams and parts listings, look at the Bulkheads parts diagram:
http://www.searspartsdirect.com/model-number/110-86873100/0582/0151200.html
And this might be the right video for replacing the heating element if you need to:
Feb 10, 2017 | Dryers
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Kenmore elite 110.629442100 parts diagram
model number doesn't come up but you can go here,put in your model number and see parts,sears.com
http://www.searspartsdirect.com/partsdirect/part-model/110.629442100
Nov 09, 2013 | Kenmore Elite He5T Dryer Heating Element...
Dryer wont stop
if when you open the door and the dryer keeps running you have a broken door switch part 3406105 go here and look at part number 41
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11076712691/0582/0151200/10051141/00002?blt=06&prst=0&shdMod=11076712691
open the door,look at the right top,there should be a paddle there that if you push in on it you should hear a clicking sound,if not switch is bad.now if you mean that it won't stop when it goes to off then you could have a bad timer part number 3976577 and it's around 100 dollars
11076712691/0582/0151200/10051141/00001?blt=06&prst=0&shdMod=11076712691
go here and it's part 3 on diagram,try it on timed dry and auto cycle and see if it stops on either cycles
Mar 16, 2013 | Kenmore Dryers
Kitchenaid prestige dryer not heating
I worked on a similar dryer with the kenmore brand on halloween. nothing had been done to the dryer since it was new. Take a look:
Kenmore 4-wheel drive dryer de-mystified!
Feb 05, 2013 | KitchenAid Dryers
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
My ge gew9250p dryer heating element is needing replacement what is a good part number for this
Hello there:
this should help you out ok
See Part # 14 on diagram.
or
See all parts for this section / diagram Heating Element (11" long x 5" wide) (Heater Element) This heating element fits later model Whirlpool/Kenmore brand electric clothes dryers. Each of its two terminals measures 5/16 of an inch, while the unit itself is approximately 11 inches long by 5 inches wide. This element carries 5200 watts and 240 volts. Appliance Help Part Number AH344597 Availability: In Stock Compare At: $56.32 Your Sale Price: $46.93 You Save: $9.39 SALE PRICE:$46.93 -->
Nov 22, 2009 | Whirlpool GEW9250P Electric Dryer
Dryer wont start
Okay...your dryer is one of the more easier dryers to access the heating circuits. All you have to do is unplug the dryer and remove the back panel. The heating circuits will be on the right hand side (as viewed from the rear). The heating element is inserted inside the heater box with the thermal cut-out (TCO) mounted on the top portion of the heat box. The hi-limit thermostat will be located adjacent to the heating element ceramic terminals. You mentioned a thermal fuse also. It is a small white plastic (sometimes gray) looking component mounted on the blower fan housing on the lower left hand side of the dryer (as viewed from the rear).
If the dryer does not run at all, the THERMAL FUSE is a good diagnosis on your part.
If the dryer runs, but does not heat, the THERMAL CUT-OUT, heating element or hi-limit thermostat are your likely problems.
The following link provides you with some necessary guidelines on how to troubleshoot if needed:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Most dryer problems are related to overheating caused by poor ventilation, or overloading. If you need a drawing of your dryer heat components you can reference searspartsdirect.com. Just type in the model number you provided (include the prefix "110", this identifies the manufacturer as Whirlpool). The number should be written as follows: 110.66801691. Look under the "Bulkhead" heading for an exploded view diagram of your dryer. The Thermal Fuse is listed as item 59 (part #3392519). I hope you find this information helpful. Let me know if you have any questions.
May 03, 2009 | Kenmore Dryers
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
Dryers Logo
99 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
