Question about Motorola Mobility HS850 Consumer Headset
Motorola HS850 dials its last number when switched on
I recently acquired a Motorola HS850 but everytime I open up the Boom to switch it on it automatically dials the last number from my dialled list. The phone I have it paired with is a Nokia 6230i. Any ideas how I could stop it doing this?
  • 1 more comment
  • Bev K Nov 09, 2007
    I have exactly the same problem. It happens on two different phones. It did not happen out of the box but has started it recently. When I open the boom (turn on the HS) after a few seconds, it dials the last number called on the phone.
  • tagman Nov 14, 2007
    I have the same exact problem as described.
  • Anonymous Dec 08, 2007
    Me too. It's been happening for the past few months.
I'm having the same issue. Someone on another forum had the same issue. They discovered that the silver button was stuck. I've checked mine to see if the button was stuck. The silver button did not move much to indicate a depressed or released position.
Posted on Dec 11, 2007
SOURCE:
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
I cannot get my phone to locate my motorola hs850 what do i need to do?
close the boom mic , press the button and hold until blue light is solid and with your spare hand flip the boom mic back open and the light should remain on. "0000" is the default passkey
Jul 05, 2009 | Motorola Mobility HS850 Consumer Headset
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Won't pair with Motorola HS850 headset
Apr 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Having problems pairing
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
Redial last number called when turning H700 on
If you are turning it on with the button, that is why. To turn on the H700, you should just need to open the boom mic. Once open, it should connect with your phone. The H700 is designed to dial the last number when the button is pressed. No way around this one.
Dec 01, 2008 | Motorola Mobility H700 Wireless Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Can not get headset inicator in steady mode for linkup
With head set off and charged, press the on button until the light comes on steady, then open the boom. The light shoulld stay on. Initiate a search for devices from the phone. This should solve part of the problem.
Jun 22, 2007 | Motorola Mobility HS850 Consumer Headset
Answering Calls with Motorola HS850 on Sony Erricson T630
i think rapid connect should work with moto phone only, isn't it?
Jan 28, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
93 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
