Question about Sony KDS-60A2000 60" HDTV
No picture or sound on kds60A2000 Sony ProjectionTV....
I have a SXRD, kds60A2000 Sony ProjectionTV. I replaced the lamp, which was broken and the problem remains. I don't know if some other problem broke the bulb, but it was over 2 yrs old. There is no picture or sound. The fans click like they want to start but they dont, and I see the flashing lights 3x then stops then 3x again over and over again. At first it was the lamp light. After the lamp was changed the lamp light stopped flashing. Now it's the power led that flashes red 3 times. Does that mean that the TV isn't getting power for some reason? Help I thought Sony was a good brand but they are getting sloppy. I paid more than 3k for their latest model which was in 11/06. I havent had the tv for even 3 yrs. yet. Please help me before I have to spend more money.
  • madman1515 Jan 25, 2009
    I have the same problem but the power led flashes red 4 times after turning green and refusing to come on.
    I too replaced my lamp then experienced this problem. It was suggested in another post that it may be the cooling fan... I intend to look into this. Have solved the problem once before (about a year ago) by taking the back off, removing the fan enclosure and cleaning / vacuuming but this is not really a safe thing to do as you can get electricuted if you touch the wrong component.
    Am having the same problem again now and an even more thorough cleaning job enabled me to power up the TV for just 1 night of viewing this time... back to 4 red lights the very next morning. It was a 11-12 month fix the first time.
    M.
4 Suggested Answers
  • 21 Answers
SOURCE: sony sxrd bulb doesnt last 9blinks
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST.
DON..
Posted on Jan 29, 2008
  • 133 Answers
SOURCE: Sony KDS60A200 won't turn on
yes, the 3 blink error code is a defolty fan, you can take the back of the tv off, it will most likelu be the fan that is faceing you on the left side, it is held bu 4 screws, take it out, (1 plug) and blow it off with canned air, or an air compresser, that will buy you a short time, you will need to order a new one on the sony website, sometimes blowing it out wont work, and sometines it will give you around a week
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Posted on Sep 09, 2009
  • 905 Answers
SOURCE: very front screen is scratche
Contact a service center for replacement. Seriously, the 60inch panel has to be removed in order to replace the front film which is no easy feat due to its size. Since it is already scratched though, you might try using a polishing kit to see if the scratches can be buffed out. Will never be back to original unless replaced, but might be worthwhile depending on scratch severity. Check with service center or local electronics retailer for the polish kit. Some rental places may be able to buff the display for you as well, but don't expect a guarantee of results. Worth the try though.
Posted on Aug 21, 2011
Replaced lamp on sony kdf 50e2000 won't turn on and blinks red, six times
Here is an answer from another site on the internet ("just ask"):
"Here is the repair tip from the Sony database.
SONY : kdf-42e2000, kdf-50e2000, kdf-55e2000,la-4 chassis : 6 blinks no main relay, replace thermal fuse on lamp housing."
Read more: sony rear projectiontv kdf-50e-2000 no power but 6 beams of - JustAnswer http://www.justanswer.com/tv-repair/1lgjk-sony-rear-projectiontv-kdf-50e-2000-no-power-beams.html#ixzz1qXESi8L2
Mar 29, 2012 | Sony KDF-50E2000 50" HDTV
Our Sony TV Model KDS60A2000 screen is black with only Video 4 on screen, has green lite showing the TV is on, however, does not have picture. Could it be the lamp?
It could be but if it is the lamp you wont be able to see anything on the screen, the screen would be black. You sould check the lamp if it looks old and burned out you may want to replace it. If you do replace it make sure not to touch the glass lens on the new lamp.
Jan 03, 2011 | Sony KDS-60A2000 60" HDTV
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
My Sony SXRD power led is blinking and the picture
your power supply has failed repair/replace it
Mar 20, 2010 | Sony KDS-70R2000 70" SXRD TV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony sxrd bulb doesnt last 9blinks
DON..
Jan 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDS-60A2000 60" HDTV Logo
255 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
